PWB Does Not Play Music Samples on Freegal Website
Public Web Browser v2.11 will only play a music sample that is listed on the opening page of the Freegal website, but it will not play any other music samples under the different categories or within the alphabetical list of music artists. It will also not play a music sample on the opening page if you return from another page on Freegal, unless you completely close the browser, re-open it ,and then log back into the website. Internet Explorer v8 will play all music samples with no problems. I have already tried changing all of the settings in the PWB.INI that weren't there by default and even several other ones just for the heck of it, but nothing helped.
Add the following to your PWB v2.11 INI file and it should correct the problem.
PreventSWFCaching=True
There is an issue with the Internet Explorer Web Browser Control PWB utilizes and the cahcing of SWF files that sometimes cause problems. This setting will remove the SWF files between pages which corrects the issue.
