I currently point to the ini file via URLINI in the shortcut. I have a website my users are accessing where the content does not display unless I remove the URLINI from the shortcut and point to the local ini file. The ini files are identical. I took an ini file that was copied via the shortcut (URLINI), made a copy of it, created a new shortcut pointing the local (copy) ini file, and the website displays correctly. Any suggestions.
Please and thanks.
WY
Mixed Results
Re: Mixed Results
What is the full Target line in the Shortcut you are using to start PWB.
Please mask the URLINI URL.
Re: Mixed Results
When I use the following I canNOT see the content on the web page:
"C:\Program Files\PublicbrowserV2\PublicBrowser.exe" /INI="C:\Program Files\PublicBrowserV2\PWB.ini" /URLINI="http://XXX.XXXX.XXX:82/prod/normal.txt"
When I make a copy of the ini file just copied by the above shortcut and rename to pwb_test.ini and use the following target I can see the content.
"C:\Program Files\PublicBrowserV2\PublicBrowser.exe" /INI="C:\Program Files\PublicBrowserV2\PWB_test.ini"
I don't understand how the shortcut target affects whether content is displayed.
I should add; I've been using the shortcut at the top for years and haven't seen this issue.
Thanks for your response.
Re: Mixed Results
Try renaming the INI file on the web site from ".txt" to ".ini", and changing the command line.
"C:\Program Files\PublicbrowserV2\PublicBrowser.exe" /INI="C:\Program Files\PublicBrowserV2\PWB.ini" /URLINI="http://XXX.XXXX.XXX:82/prod/[b]normal.INI[/b]"
Also note, if you are using Windows Vista or Windows 7 the "Program Files" folder is read only and will not work with the URLINI command line switch.
Re: Mixed Results
I'm using Windows Embedded for Point of Sale (WEPOS) and have been using that shortcut/target since PWB v1. I'll test your recommendation.
Re: Mixed Results
Tried the suggestion, after adding .ini to MIME type, but it didn't help. My users are attempting to access a training slideshow on our local intranet. We have multiple training demonstrations (mostly videos) that they can and have accessed for years (using PWB [have since v1]). Now, the only way they can see the content on the webpage, the slideshow, is if pwb.ini is on the local machine. The page loads but the internal frame or content does not. It does not work when pulling the ini from my webserver.
I'm baffled.
W
I'm baffled.
W
Re: Mixed Results
Using the URLINI command line switch downloads the INI file from the path in the URLINI switch to the path in the INI switch.
Is the INI file being downloaded when PWB starts?
Another aspect, the PWB version 2 executable is called "PWB.EXE". In your command line you have "PublicBrowser.exe", are you using PWB version 2?
Re: Mixed Results
Yes, it is being downloaded. I'm using version 2. If I remember correctly, I changed the exe name, when we upgraded to v2, so I wouldn't have to change my shortcuts. I checked the exe version and it is 2.1.1.5.
Re: Mixed Results
When it is downloaded is it named "PWB.ini"?
Re: Mixed Results
Yes. The shortcut works.
Re: Mixed Results
If PWB is downloading the new INI file correctly then it should be working as PWB downloads then reads the INI file that was downloaded.
Where are you running the Shortcut from, the Startup folder on the Start Menu?
