Manual Install
Doug Payne
Manual Install
Post by Doug Payne »
One of the downloads for PWDv2 is for a manual install. I
unpacked this. There aren't any special installation notes.
Can I just put this in a directory and run it from there?
I could use the version for Win2000, with the installer, but
it would make it easier to roll out to new PCs if all I had
to do was copy the files to the new PC.
-- Doug
Doug Payne
Mugar Library / Boston Univ.
dbp@bu.edu
You can simple unpack the manual install and PWB is installed. Really the only thing the installer does is copy the files to the Program Files folder and create the Start Menu icons.
In fact once you get PWB configured you can copy the PWB folder from computer to computer to install it.
