Password to disable proxy server
How can we make our software better?
George Yobst
Post by George Yobst »
In light of the CIPA ruling, if we use a network proxy filtering server, can an override password be added to completely bypass the proxy server?
Thanks! -George
I will see what I can do.
I believe the IE HTML rendering engine only reads the proxy settings when it is instantiated. This may prove to be a problem unless PWB is restarted.
George Yobst
OK, then how about adding the ask proxy function that v1.28 had under the Addons section to v2? I could live with adult stations that asked up front if they wanted filtered or not. -George
That should not be a problem to add to PWB v2. I will put it on our to-do list for PWB v2.05.
