Does not display pbskids.org/go/ and pbskids.org correctly
phillipbrickner
- Contributor
When going to pbskids.org with pwb v2 or v3 the footer on this page is displayed weird/ not correctly. Also when going to pbskids.org/go/ in an Iframe also shows up weird/ broken table and broken slider. Is there any thing I can do to make this render correctly?
Re: Does not display pbskids.org/go/ and pbskids.org correct
What version of Windows, Internet Explorer, and Flash Player, are you using with PWB?
It looks the same as IE on Windows 7, Internet Explorer 10, and Flash Player 11.8.
- Screen shot.
- pbs2.png (300.03 KiB) Viewed 166595 times
- Screen shot.
- pbs.png (294.94 KiB) Viewed 166595 times
phillipbrickner
- Contributor
Windows 7 64bit, I was using IE 9 but I upgraded to 10 after seeing that it worked for you, and Flash Player 11.8
It is still making the footer look all messed up
The other page pbskids.org/go looks good normally but when I put it in an Iframe it gets messed up. This could be because of the width of the Iframe.
below is my pwb.ini
[AutoRegister]
RegisterKey=
RegisterPassword=
RegisterDaysLeft=30
RegisterSeconds=15
RegisterShowWindow=FALSE
UseWindowsRegistry=FALSE
RegisterDelayClose=FALSE
RegisteredTo=Upper Arlington Public Library
RegistrationNumber=XXXXXXXXXXXXXXXX
IniFileVersion=2.11
Title=Upper Arlington Public Library
KioskMode=TRUE
DesktopMode=FALSE
HomePage=http://pbskids.org/
CommandLineHomePage=FALSE
SearchPage=
WebMailPage=
AddressBarText=Address:
DefaultFontSize=2
DefaultSendLink=TRUE
StartMaximized=TRUE
AlwaysOnTop=FALSE
WindowHeight=-1
WindowWidth=-1
WindowTop=-1
WindowLeft=-1
ShowMenuBar=FALSE
ShowToolBar=FALSE
ShowShellBar=FALSE
ShowAddressBar=FALSE
ShowAnimation=TRUE
ShowStatusBar=TRUE
ShowTitleBar=FALSE
ShowBackButtonMenu=TRUE
ShowInactivityTimer=TRUE
ShowActivityTimer=FALSE
ShowStatusBarTime=TRUE
ShowURLInBrowserCaption=FALSE
DisableMinimizeButton=FALSE
DisableMaximizeButton=FALSE
DisableCloseButton=FALSE
DisableMoveWindow=FALSE
DisableResizeWindow=FALSE
DisableNewWindow=FALSE
DisableINIVersionCheck=FALSE
DisableExit=FALSE
ConfirmClose=FALSE
UseIEFavorites=FALSE
ShowGoButton=FALSE
GoButtonText=Go
AlwaysOnBottom=FALSE
ShellButtonIconWidth=
ShellButtonIconHeight=
DisableIESubClass=FALSE
ShowWindowRelation=FALSE
MainWindowIndicator=(Main)
ShowKioskBar=TRUE
F1HelpPageURL=
ShowSplashScreen=FALSE
DisableAutoComplete=TRUE
ShellExecuteScripts=FALSE
OpenLinksInNewWindow=FALSE
DisableCtrlEnter=TRUE
SaveWindowPosition=TRUE
MinimizeMemoryUsage=FALSE
StartTimersOnMouseKeyboard=FALSE
AddStationToUserAgent=FALSE
EnableAdvancedClose=TRUE
UpdateWindowOnTime=FALSE
RedrawWindowSeconds=-1
ConfigRegLocation=
DisableScrollBars=FALSE
MapContextPrintToButton=FALSE
PreventHTMLClosingMainWindow=FALSE
AddressBarReadOnly=FALSE
EnableIEFeatures=FALSE
ShowAddressInBrowserCaption=FALSE
MaximizeOnNonsizeable=FALSE
SecureMode=TRUE
HideCursor=FALSE
ExitPage=
ShowSearchBar=FALSE
SearchBarText=
SearchBarPage=
StatusBarTimeFormat=
StatusBarTimeWidth=32
DefaultZoomLevel=100
IEBrowserEmulation=8000
[SecondWindow]
AlwaysOnTop=TRUE
LimitCount=1
DisableMinimizeButton=TRUE
DisableMaximizeButton=TRUE
DisableMoveWindow=TRUE
DisableResizeWindow=TRUE
DisableTitleBar=FALSE
WindowHeight=-1
WindowWidth=-1
WindowTop=10
WindowLeft=10
NewPageAsHome=FALSE
OpenInParentWindow=FALSE
DisableUnrequested=FALSE
StartOnDesktopMode=FALSE
OpenDesktopModeLink=TRUE
ShowTimers=FALSE
ShellBarURLNewWindow=FALSE
ShowShellBar=FALSE
StartMaximized=TRUE
CloseChildrenOnClose=TRUE
SecondWindowIndicator=(Secondary)
OpenInNewProcess=FALSE
ShowGoButton=FALSE
ShowKioskBar=FALSE
ShowToolBar=FALSE
ShowMenuBar=FALSE
ShowStatusBar=FALSE
DisableShiftClick=FALSE
OpenInFrame=
ForceToFront=TRUE
ShowSearchBar=FALSE
[ToolBars]
MenuBarGripper=TRUE
ToolBarBreak=TRUE
ToolBarGripper=TRUE
ToolBarChevron=TRUE
ShellBarBreak=FALSE
ShellBarGripper=TRUE
ShellBarChevron=TRUE
AddressBarBreak=TRUE
AddressBarGripper=TRUE
MenuBarWidth=0
ToolBarWidth=0
ShellBarWidth=0
AddressBarWidth=0
GoButtonGripper=TRUE
GoButtonBreak=FALSE
AlignBottom=FALSE
KioskBarScrollBy=40
AutoSizeButtons=FALSE
ButtonTextRight=FALSE
ToolBarIconHeight=0
ToolBarIconWidth=0
ShellButtonIconWidth=0
ShellButtonIconHeight=0
KioskBarButtonColor=
KioskBarBackGroundColor=
KioskToolBarIconHeight=-1
KioskToolBarIconWidth=-1
SearchBarWidth=100
SearchBarBreak=FALSE
SearchBarGripper=FALSE
[Printer]
ShowPrintButtonDialog=FALSE
ForcePrintPreview=FALSE
UseLimitPrintJobs=FALSE
LimitPrintJobs=0
PrintJobLimitTitle=Print Limit
PrintJobLimitMessageFile=
ShowPrintingDialog=TRUE
PrintingTitle=Page Printing
PrintingMessageFile=Printing.txt
CheckPrintAccess=TRUE
PrintDialogShowCancel=TRUE
ShowPrintMenuDialog=TRUE
PrintTemplateFile=
ShowPrintIDDialog=FALSE
PrintIDDialogTitle=Print Identification
PrintIDDialogHeight=0
PrintIDDialogWidth=0
PrintIDDialogFile=printID.htm
AddSystemMenuPrint=FALSE
[Dialogs]
DialogSeconds=15
PolicyTitle=Policy
AccessTitle=Warning: Denied
ConfirmCloseDefaultNo=TRUE
ConfirmCloseTitle=Confirm Close
PolicyHeight=0
PolicyWidth=0
ConfirmCloseSoundFile=
AccessDeniedSoundFile=
AlwaysOnTop=TRUE
SecondInstanceTitle=Second Instance
IncorrectPasswordMessage=Incorrect password entered?
AccessURLRedirect=
PolicyShowDecline=TRUE
PolicyShowClock=TRUE
MessageHeight=0
MessageWidth=0
OkButtonText=Ok
CancelButtonText=Cancel
DeclineButtonText=Decline
AcceptButtonText=Accept
YesButtonText=Yes
NoButtonText=No
ShowPopupMessage=FALSE
PopupOnMessageTitle=Pop-ups are on
PopupOffMessageTitle=Pop-ups are off
UseHtmlDialogs=FALSE
MessageTop=0
MessageLeft=0
WorkingAnimation=
PolicyFile=Policy.txt
HistoryFile=History.txt
CheckURLFile=URL.txt
CheckIPFile=IP.txt
PopupAdFile=Popup.txt
AccessMessageFile=Access.rtf
ConfirmCloseMessageFile=
SaveAsErrorMessageFile=
FavoritesFolder=Favorites
ShellBarFolder=ShellBar
StartupScript=
ShutdownScript=
PolicyDeclineScript=
DesktopFile=
SendToApp=
CheckPrintFile=
PopupOnButtonFile=
PopupOffButtonFile=
PasswordFile=
NewWindowProcessINI=
InactivityScript=
CheckPostDataFile=
CheckACFile=
ActivityScript=
TimeCheckScriptDay=
TimeCheckScriptNight=
ToolBarIconFolder=
CheckURLRedirectFile=C:\Program Files (x86)\TeamSoftware Solutions\Public Web Browser v2\URLDirect.txt
SendToAppFile=
SendToAppLink=
[WebFiles]
EnableWebFiles=FALSE
CheckIPFile=
CheckPrintFile=
PopupAdFile=
[Directories]
SaveAsDirectory=Floppy required
SaveAsErrorTitle=Floppy required
DownloadDirectory=Floppy required
DownloadErrorTitle=Floppy required
[RestrictedSave]
EnableRestrictedSave=FALSE
RestrictedSaveApp=
StationEnvironmentVariable=COMPUTERNAME
UseUniqueHistoryFiles=FALSE
WriteHistoryFile=FALSE
TrackURL=FALSE
CheckURLAccess=TRUE
CheckIPAccess=FALSE
ClosePopupAds=FALSE
ShowAccessDialog=TRUE
LogAccess=FALSE
ClearCacheOnHome=FALSE
ClearCacheOnClose=FALSE
DisableAddressDropDown=FALSE
DisableContextMenu=FALSE
UseCustomContextMenu=TRUE
ShowPolicyDialog=FALSE
OnlyAccessHTTP=FALSE
DisableSecondInstance=FALSE
RestartOnClose=TRUE
ShowPasswordDialog=FALSE
PasswordTitle=Public Web Browser
Password=password
CheckInitialURL=FALSE
DisableFileDownload=FALSE
AllowSingleLinkLevel=FALSE
AllowBrowseOnDeny=FALSE
LogoffOnExit=FALSE
ShowFilterStatus=FALSE
FilterOnText=<Filter On>
FilterOffText=<Filter Off>
ShowProxyStatus=FALSE
ProxyOnText=<Proxy On>
ProxyOffText=<Proxy Off>
ShowDenyDialogOncePerSession=FALSE
OnlyAccessInternet=FALSE
DebugAccessString=FALSE
AllowLinkLevelDepth=0
CheckPostDataAccess=FALSE
DisableFileUploads=FALSE
TrackLogon=FALSE
CacheFilterFiles=FALSE
CheckACAccess=FALSE
SecondInstanceNavigateCurrent=FALSE
RebootOnExit=FALSE
CheckURLRedirect=True
PreventFileDownload=FALSE
EnableFileDownload=FALSE
EnableAlternateOverrideKeys=FALSE
LogDeniedAccess=FALSE
EnableFilterOrLogic=FALSE
[Overrides]
ExitBrowser=
Logoff=
Shutdown=
ResetActvityTime=
ResetPrintLimit=
RestrictedSave=
ReReadINIFile=
OpenSysedit=
OpenRegedit=
OpenExplorer=
DisableProxy=
DisableFilters=
ShowAddressBar=
OverrideURLKeyword=
[HTMLError]
EnableRedirect=FALSE
DebugErrorNumber=FALSE
[Java]
EnableExternalJava=TRUE
JavaExit=
JavaActivity=
JavaRegister=
JavaHideToolbar=
JavaExecute=PWBExecute
JavaReadINIFile=
JavaPrint=
JavaHideAddressBar=
JavaPrintFrame=
JavaFillElement=
JavaRegistryRegister=
JavaLogoff=
JavaReboot=
JavaShutdown=
JavaOverrides=
JavaStartApp=
JavaSetActivity=
JavaGetActivity=
[ScreenSaver]
EnableScreenSaver=FALSE
ScreenSaverSeconds=1200
EnablePolicyScreenSaver=FALSE
PolicyScreenSaverSeconds=10
DisableScreenSaverOnPolicyClose=FALSE
DisableScreenSaverOnClose=FALSE
WindowsScreenSaverExe=
WindowsScreenSaverMinutes=0
InactivitySeconds=300
InactivityMessageTitle=
InactivityMessageFile=
InactivityAction=Exit
InactivitySoundFile=
InactivityStartOnOpen=FALSE
InactivityShowDialog=TRUE
ResetOnMouseMove=TRUE
ResetOnMouseButton=TRUE
ResetOnKeyboard=TRUE
[Activity]
ActivityTimer=FALSE
ActivitySeconds=1200
ActivityMessageTitle=Warning
ActivityMessageFile=Activity.txt
ActivityWarnAt=120
ActivityWarnTitle=Warning
ActivityWarnMessageFile=ActivityWarn.txt
ActivityAction=Exit
ActivitySoundFile=
ActivityStartOnOpen=FALSE
ActivityShowInTitleBar=TRUE
ActivitySecondWarnAt=5
ActivitySecondWarnMessageFile=ActivityWarn.txt
DisableDialogTimer=FALSE
[TimeCheck]
EnableTimeCheck=FALSE
TimeToActionDay=10:14:00
TimeToActionNight=
TimeToWarnSeconds=300
MessageTitleDay=Day Action
MessageFileDay=Access.txt
MessageTitleNight=
MessageFileDNight=
MessageTitleWarnDay=Day Warning
MessageFileWarnDay=Access.txt
MessageTitleWarnNight=
MessageFileWarnNight=
ActionDay=Exit
ActionNight=
[Proxy]
UseCustom=FALSE
ProxyEnable=FALSE
ProxyServer=
ProxyOverride=
AutoConfigURL=
[PageSetup]
UseCustom=FALSE
Footer=&u&b&d
Header=&w&bPage &p of &P
MarginBottom=0.75000
MarginLeft=0.75000
MarginRight=0.75000
MarginTop=0.75000
Duplex=1
Orientation=1
[Buttons]
Back=TRUE
Forward=TRUE
Separator1=FALSE
Stop=TRUE
Refresh=TRUE
Home=TRUE
Separator2=TRUE
Search=FALSE
Favorites=FALSE
Print=TRUE
PrintPreview=TRUE
Separator3=FALSE
Send=FALSE
WebMail=FALSE
Separator4=FALSE
About=FALSE
Policy=FALSE
Separator5=TRUE
New=FALSE
Save=FALSE
Separator6=FALSE
Cut=FALSE
Copy=FALSE
Paste=FALSE
Find=FALSE
TextSize=TRUE
Encoding=FALSE
Popup=FALSE
Shell=FALSE
Zoom=
[KioskButtons]
Back=FALSE
Separator1=FALSE
Forward=FALSE
Separator2=FALSE
Stop=FALSE
Separator3=FALSE
Refresh=FALSE
Separator4=FALSE
Home=FALSE
Separator5=FALSE
Print=FALSE
Separator6=FALSE
ScrollUp=FALSE
Separator7=FALSE
ScrollDown=FALSE
Separator8=FALSE
Close=FALSE
TextSize=FALSE
Separator9=FALSE
[MenuItems]
FileMenu=FALSE
FileNew=FALSE
FileOpen=FALSE
FileSaveAs=FALSE
FileSeparator1=TRUE
FilePageSetup=TRUE
FilePrintPreview=TRUE
FilePrint=TRUE
FileSeparator2=FALSE
FileSend=FALSE
FileSendFile=FALSE
FileSendLink=FALSE
FileSeparator3=TRUE
FileProperties=FALSE
FileExit=FALSE
EditMenu=TRUE
EditCut=TRUE
EditCopy=TRUE
EditPaste=TRUE
EditSeparator1=TRUE
EditSelectAll=TRUE
EditSeparator2=TRUE
EditFind=TRUE
ViewMenu=TRUE
ViewToolbar=True
ViewStatusBar=True
ViewSeparator1=TRUE
ViewGoto=TRUE
ViewGotoBack=TRUE
ViewGotoForward=TRUE
ViewGotoHome=TRUE
ViewGotoSearch=FALSE
ViewStop=TRUE
ViewRefresh=TRUE
ViewTextSize=TRUE
ViewTextSizeLargest=TRUE
ViewTextSizeLarge=TRUE
ViewTextSizeMedium=TRUE
ViewTextSizeSmall=TRUE
ViewTextSizeSmallest=TRUE
ViewSeparator2=TRUE
ViewSource=FALSE
ShellMenu=FALSE
FavoritesMenu=FALSE
FavoritesAdd=FALSE
FavoritesOrganize=FALSE
FavoritesSeparator=FALSE
HelpMenu=FALSE
HelpPolicy=FALSE
HelpAbout=FALSE
ViewZoom=
ViewZoomIncrease=Increase Ctrl+
ViewZoomDecrease=Decrease Ctrl-
ViewZoomLarge=Large
ViewZoomNormal=Normal
ViewZoomSmall=Small
ViewZoomCustom=Custom
ViewEncoding=TRUE
[ContextMenu]
OpenLink=TRUE
OpenLinkNew=FALSE
SaveTarget=FALSE
PrintTarget=FALSE
Separator1=TRUE
ShowPicture=FALSE
SavePicture=FALSE
SetWallPaper=FALSE
SetDeskTopItem=FALSE
Separator2=FALSE
Cut=FALSE
Copy=FALSE
CopyShortcut=FALSE
Paste=FALSE
Separator3=FALSE
Encoding=FALSE
Separator4=FALSE
Print=FALSE
Refresh=TRUE
Separator5=FALSE
Properties=FALSE
Back=Back
Forward=Forward
Separator0=TRUE
[URLKeys]
EnableURLKeys=FALSE
EnableURLFKeys=FALSE
[Addons]
PWBDisableStartMenu=C:\Program Files (x86)\TeamSoftware Solutions\Public Web Browser v2\PWBDisableStartMenu.dll
below is my pwb.ini
[AutoRegister]
RegisterKey=
RegisterPassword=
RegisterDaysLeft=30
RegisterSeconds=15
IniFileVersion=2.11
KioskMode=TRUE
DesktopMode=FALSE
SearchPage=
WebMailPage=
DefaultFontSize=2
StartMaximized=TRUE
AlwaysOnTop=FALSE
WindowHeight=-1
WindowWidth=-1
WindowTop=-1
WindowLeft=-1
ShowMenuBar=FALSE
ShowToolBar=FALSE
ShowShellBar=FALSE
ShowAnimation=TRUE
ShowStatusBar=TRUE
ShowTitleBar=FALSE
DisableExit=FALSE
ConfirmClose=FALSE
ShowGoButton=FALSE
GoButtonText=Go
ShowKioskBar=TRUE
F1HelpPageURL=
ConfigRegLocation=
SecureMode=TRUE
HideCursor=FALSE
ExitPage=
ShowSearchBar=FALSE
SearchBarText=
SearchBarPage=
[SecondWindow]
AlwaysOnTop=TRUE
LimitCount=1
WindowHeight=-1
WindowWidth=-1
WindowTop=10
WindowLeft=10
NewPageAsHome=FALSE
ShowTimers=FALSE
ShowShellBar=FALSE
StartMaximized=TRUE
ShowGoButton=FALSE
ShowKioskBar=FALSE
ShowToolBar=FALSE
ShowMenuBar=FALSE
ShowStatusBar=FALSE
OpenInFrame=
ForceToFront=TRUE
ShowSearchBar=FALSE
[ToolBars]
MenuBarGripper=TRUE
ToolBarBreak=TRUE
ToolBarGripper=TRUE
ToolBarChevron=TRUE
ShellBarBreak=FALSE
MenuBarWidth=0
ToolBarWidth=0
ShellBarWidth=0
AddressBarWidth=0
GoButtonBreak=FALSE
AlignBottom=FALSE
KioskBarScrollBy=40
ToolBarIconHeight=0
ToolBarIconWidth=0
SearchBarWidth=100
[Printer]
LimitPrintJobs=0
PrintTemplateFile=
[Dialogs]
DialogSeconds=15
PolicyTitle=Policy
PolicyHeight=0
PolicyWidth=0
AlwaysOnTop=TRUE
AccessURLRedirect=
MessageHeight=0
MessageWidth=0
OkButtonText=Ok
YesButtonText=Yes
NoButtonText=No
MessageTop=0
MessageLeft=0
WorkingAnimation=
CheckIPFile=IP.txt
StartupScript=
ShutdownScript=
DesktopFile=
SendToApp=
CheckPrintFile=
PopupOnButtonFile=
PopupOffButtonFile=
PasswordFile=
InactivityScript=
CheckPostDataFile=
CheckACFile=
ActivityScript=
TimeCheckScriptDay=
ToolBarIconFolder=
SendToAppFile=
SendToAppLink=
[WebFiles]
CheckIPFile=
CheckPrintFile=
PopupAdFile=
[Directories]
[RestrictedSave]
RestrictedSaveApp=
TrackURL=FALSE
CheckURLAccess=TRUE
CheckIPAccess=FALSE
ClosePopupAds=FALSE
LogAccess=FALSE
RestartOnClose=TRUE
Password=password
LogoffOnExit=FALSE
TrackLogon=FALSE
CheckACAccess=FALSE
RebootOnExit=FALSE
[Overrides]
ExitBrowser=
Logoff=
Shutdown=
ResetActvityTime=
ResetPrintLimit=
RestrictedSave=
ReReadINIFile=
OpenSysedit=
OpenRegedit=
OpenExplorer=
DisableProxy=
DisableFilters=
ShowAddressBar=
OverrideURLKeyword=
[HTMLError]
[Java]
JavaExit=
JavaActivity=
JavaRegister=
JavaHideToolbar=
JavaReadINIFile=
JavaPrint=
JavaHideAddressBar=
JavaPrintFrame=
JavaFillElement=
JavaLogoff=
JavaReboot=
JavaShutdown=
JavaOverrides=
JavaStartApp=
JavaSetActivity=
JavaGetActivity=
[ScreenSaver]
[Activity]
ActivityTimer=FALSE
ActivityWarnAt=120
ActivityAction=Exit
ActivitySoundFile=
[TimeCheck]
TimeToActionNight=
MessageTitleNight=
MessageFileDNight=
ActionDay=Exit
ActionNight=
[Proxy]
UseCustom=FALSE
ProxyEnable=FALSE
ProxyServer=
ProxyOverride=
AutoConfigURL=
[PageSetup]
UseCustom=FALSE
Footer=&u&b&d
MarginLeft=0.75000
MarginRight=0.75000
MarginTop=0.75000
Duplex=1
Orientation=1
[Buttons]
Back=TRUE
Forward=TRUE
Separator1=FALSE
Stop=TRUE
Refresh=TRUE
Home=TRUE
Separator2=TRUE
Search=FALSE
Favorites=FALSE
Print=TRUE
PrintPreview=TRUE
Separator3=FALSE
Send=FALSE
WebMail=FALSE
Separator4=FALSE
About=FALSE
Policy=FALSE
Separator5=TRUE
New=FALSE
Save=FALSE
Separator6=FALSE
Cut=FALSE
Copy=FALSE
Paste=FALSE
Find=FALSE
TextSize=TRUE
Encoding=FALSE
Popup=FALSE
Shell=FALSE
Zoom=
[KioskButtons]
Back=FALSE
Separator1=FALSE
Forward=FALSE
Separator2=FALSE
Stop=FALSE
Separator3=FALSE
Refresh=FALSE
Separator4=FALSE
Home=FALSE
Separator5=FALSE
Print=FALSE
Separator6=FALSE
ScrollUp=FALSE
Separator7=FALSE
ScrollDown=FALSE
Separator8=FALSE
Close=FALSE
TextSize=FALSE
Separator9=FALSE
[MenuItems]
FileMenu=FALSE
FileNew=FALSE
FileOpen=FALSE
FileSaveAs=FALSE
FileSeparator1=TRUE
FilePageSetup=TRUE
FilePrint=TRUE
FileSend=FALSE
FileSendFile=FALSE
FileSendLink=FALSE
FileSeparator3=TRUE
FileExit=FALSE
EditMenu=TRUE
EditCut=TRUE
EditCopy=TRUE
EditPaste=TRUE
EditSeparator1=TRUE
EditSelectAll=TRUE
EditSeparator2=TRUE
EditFind=TRUE
ViewMenu=TRUE
ViewToolbar=True
ViewStatusBar=True
ViewSeparator1=TRUE
ViewGoto=TRUE
ViewGotoBack=TRUE
ViewGotoHome=TRUE
ViewStop=TRUE
ViewRefresh=TRUE
ViewTextSize=TRUE
ViewSeparator2=TRUE
ViewSource=FALSE
ShellMenu=FALSE
FavoritesMenu=FALSE
FavoritesAdd=FALSE
HelpMenu=FALSE
HelpPolicy=FALSE
HelpAbout=FALSE
ViewZoom=
ViewZoomLarge=Large
ViewZoomSmall=Small
ViewEncoding=TRUE
[ContextMenu]
OpenLink=TRUE
OpenLinkNew=FALSE
SaveTarget=FALSE
PrintTarget=FALSE
Separator1=TRUE
ShowPicture=FALSE
SavePicture=FALSE
SetWallPaper=FALSE
Separator2=FALSE
Cut=FALSE
Copy=FALSE
CopyShortcut=FALSE
Paste=FALSE
Separator3=FALSE
Encoding=FALSE
Separator4=FALSE
Print=FALSE
Refresh=TRUE
Separator5=FALSE
Properties=FALSE
Back=Back
Forward=Forward
Separator0=TRUE
[URLKeys]
EnableURLKeys=FALSE
[Addons]
This setting is changing PWB in to IE Compatibility mode.
Set it to blank to allow PWB to use IE in native mode.
IEBrowserEmulation=
IEBrowserEmulation=
phillipbrickner
- Contributor
I just tried changing the IEBrowserEmulation to nothing and it is still not working. Any other suggestions?
Try using an unedited INI file. Does this correct it?
Through elimination we narrowed it down to this setting in your INI file.
This needs to be true in order to allow PWB to enable some Internet Explorer features that are being used by the site.
Setting the following in your INI file will correct the issue.
EnableIEFeatures=TRUE
phillipbrickner
- Contributor
That fixed it
Thanks for the quick responses. You guys are awesome!
phillipbrickner
- Contributor
After changing that setting I am now seeing the windows active x bar asking me to allow content. The page I am trying to display is a local page on the PC with javascript.
The message:
To help protect your security, your web browser has restricted this file from showing active content that could access your computer. Click here for options.
I tried setting tools>internet options>Advanced> Under Security > Allow active content to run in files from my computer
Is there a way in public web browser to allow all active x popups like this or to put the files or local C: on an allow list?
The message:
You should be able to click the bar for options and turn it off.
You are seeing the IE messages because PWB hosts IE which can be configured through the Control Panel applet Internet Options for each user.
The IE settings are set per user and can be controlled via a Group Policy or by manipulating the Windows Registry directly.
Do you have an example of the page that we could test?
phillipbrickner
- Contributor
Its a local web page here is the code for the HTML.
<html>
<head>
<link rel="STYLESHEET" href="./kids.css" type="text/css" />
<script language="JavaScript">
var d = new Date();
var month = d.getMonth();
var day = d.getDate();
var monthday = ((month+1)*100)+day;
var fall = new Array("backgrounds/UAPL-Y-Gaming-Center-Land-Pg-Bckgrd-1.jpg","backgrounds/UAPL-Y-Gaming-Center-Land-Pg-Bckgrd-1.jpg");
var summer = new Array("backgrounds/UAPL-Y-Gaming-Center-Land-Pg-Bckgrd-1.jpg","backgrounds/UAPL-Y-Gaming-Center-Land-Pg-Bckgrd-1.jpg");
var winter = new Array("backgrounds/UAPL-Y-Gaming-Center-Land-Pg-Bckgrd-1.jpg","backgrounds/UAPL-Y-Gaming-Center-Land-Pg-Bckgrd-1.jpg");
var spring = new Array("backgrounds/UAPL-Y-Gaming-Center-Land-Pg-Bckgrd-1.jpg","backgrounds/UAPL-Y-Gaming-Center-Land-Pg-Bckgrd-1.jpg");
//---------- show background based on season
if (( monthday > 1220) || ( monthday < 320)) {
var background = winter[Math.floor((winter.length)*Math.random())];
} else if (( monthday > 319) && ( monthday < 621)) {
var background = spring[Math.floor((spring.length)*Math.random())];
} else if (( monthday > 620) && ( monthday < 922)) {
var background = summer[Math.floor((summer.length)*Math.random())];
} else if (( monthday > 921) && ( monthday < 1221)) {
var background = fall[Math.floor((fall.length)*Math.random())];
} else {
var background = "";
function box_art_hide()
document.getElementById('darkenScreenObject').style.visibility='hidden';
document.getElementById('box_art').style.background='black';
document.getElementById('box_art').style.visibility='hidden';
function box_art_display(picture,link)
var play_link = "JavaScript:window.external.PWBExecute('C:\\\\shortcuts\\\\" + link + '\')';
var display_background = "url('" + picture + "')";
document.getElementById('link_change').href= play_link;
document.getElementById('darkenScreenObject').style.visibility='visible';
document.getElementById('box_art').style.background= display_background;
document.getElementById('box_art').style.visibility='visible';
function loading_game()
document.getElementById('darkenScreenObject2').style.visibility='visible';
document.getElementById('popup').style.visibility='visible';
setTimeout("hidePopup('popup')", 10000); // after 5 sec
function hidePopup()
document.getElementById('darkenScreenObject2').style.visibility='hidden';
document.getElementById('popup').style.visibility='hidden';
box_art_hide();
function fade_out()
if(document.getElementById('fade_div').filters('alpha').opacity > 0)
document.getElementById('fade_div').filters('alpha').opacity -= 10;
setTimeout('fade_out()',100);
else
document.getElementById('fade_div').style.visibility = 'hidden';
function fade_in(link)
document.getElementById('fade_div').style.visibility = 'visible';
if(document.getElementById('fade_div').filters('alpha').opacity < 100)
document.getElementById('fade_div').filters('alpha').opacity += 10;
setTimeout(fade_in(link),100);
else
window.location = link;
function icon_down(this_div) {
document.getElementById(this_div).style.filter='alpha(opacity = 50)';
function icon_up(this_div, link){
document.getElementById(this_div).style.filter='alpha(opacity = 100)';
fade_in(link);
function icon(this_div, link) {
fade_in(link);
</script>
</head>
document.write('<body onLoad="fade_out();" "BGCOLOR="#222222" background="' + background + '" >')
</script>
<div id="fade_div" style="filter:Alpha(opacity=100); visibility:visible;"></div>
<div id="darkenScreenObject" style="visibility:hidden;"></div>
<div id="darkenScreenObject2" style="visibility:hidden;"></div>
<div id="header" style="background-image: url(backgrounds/UAPL-Y-Gaming-Center-Land-Pg-Title.png); background-repeat: no-repeat; background-position: center;"></div>
<div id="landingbutton1" style="background-image: url(icons/UAPL-Y-Gaming-Center-Land-Pg-Blue-Button.png); background-repeat: no-repeat; background-position: center;" onmousedown="icon_down('landingbutton1', 'kids_1.html'); " onmouseup="icon_up('landingbutton1', 'kids_1.html');" onclick="icon('landingbutton1', 'kids_1.html');" ondblclick="icon('landingbutton1', 'kids_1.html');"></div>
<div id="landingbutton2" style="background-image: url(icons/UAPL-Y-Gaming-Center-Land-Pg-Purple-Button.png); background-repeat: no-repeat; background-position: center;" onmousedown="icon_down('landingbutton2', 'kids_2.html'); " onmouseup="icon_up('landingbutton2', 'kids_2.html');" onclick="icon('landingbutton2', 'kids_2.html');" ondblclick="icon('landingbutton2', 'kids_2.html');"></div>
<div id="landingbutton3" style="background-image: url(icons/UAPL-Y-Gaming-Center-Land-Pg-Orange-Button.png); background-repeat: no-repeat; background-position: center;" onmousedown="icon_down('landingbutton3', 'kids_3.html'); " onmouseup="icon_up('landingbutton3', 'kids_3.html');" onclick="icon('landingbutton3', 'kids_3.html');" ondblclick="icon('landingbutton3', 'kids_3.html');"></div>
<div id="landingbutton4" style="background-image: url(icons/UAPL-Y-Gaming-Center-Land-Pg-Kids-Web-Button.png); background-repeat: no-repeat; background-position: center;" onmousedown="icon_down('landingbutton4', 'kids_internet.html'); " onmouseup="icon_up('landingbutton4', 'kids_internet.html');" onclick="icon('landingbutton4', 'kids_internet.html');" ondblclick="icon('landingbutton4', 'kids_internet.html');"></div>
</body>
</html>
<html>
<head>
var d = new Date();
} else {
box_art_hide();
function fade_out()
else
else
fade_in(link);
fade_in(link);
</script>
</head>
</script>
</body>
</html>
phillipbrickner
- Contributor
Here is the css file. Name this one kids.css and put it in the same folder as the html page.
#header{
position:absolute;
top:10px;
left:280px;
width:1600px;
height:300px;
z-index: 0;
#home{
position:absolute;
top:25px;
left:25px;
width:250px;
height:250px;
z-index: 0;
#8box{
position:absolute;
top:305px;
left:310px;
width:1280px;
height:640px;
border: none;
z-index: 0;
padding: 0px;
#6box{
position:absolute;
top:305px;
left:470px;
width:960px;
height:640px;
border: none;
z-index: 0;
padding: 0px;
#4box{
position:absolute;
top:305px;
left:630px;
width:640px;
height:640px;
border: none;
z-index: 0;
padding: 0px;
#2box{
position:absolute;
top:305px;
left:250px;
width:640px;
height:640px;
border: none;
z-index: 0;
padding: 0px;
#bigbox1{
position:absolute;
top:0px;
left:0px;
width:640px;
height:640px;
border: none;
padding: 0px;
margin: 0px;
#bigbox2{
position:absolute;
top:0px;
left:780px;
width:640px;
height:640px;
border: none;
padding: 0px;
margin: 0px;
#landingbutton1{
position:absolute;
top:305px;
left:170px;
width:705px;
height:350px;
border: none;
padding: 0px;
margin: 0px;
#landingbutton2{
position:absolute;
top:305px;
right:170px;
width:705px;
height:350px;
border: none;
padding: 0px;
margin: 0px;
#landingbutton3{
position:absolute;
top:660px;
left:170px;
width:705px;
height:350px;
border: none;
padding: 0px;
margin: 0px;
#landingbutton4{
position:absolute;
top:660px;
right:170px;
width:705px;
height:350px;
border: none;
padding: 0px;
margin: 0px;
#box1{
position:absolute;
top:0px;
left:0px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box2{
position:absolute;
top:0px;
left:320px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box3{
position:absolute;
top:0px;
left:640px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box4{
position:absolute;
top:0px;
left:960px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box5{
position:absolute;
top:320px;
left:0px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box6{
position:absolute;
top:320px;
left:320px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box7{
position:absolute;
top:320px;
left:640px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box8{
position:absolute;
top:320px;
left:960px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#left_arrow{
position:absolute;
top:465px;
left:0px;
width:300px;
height:284px;
border: none;
padding: 0px;
margin: 0px;
#right_arrow{
position:absolute;
top:465px;
right:0px;
width:300px;
height:284px;
border: none;
padding: 0px;
margin: 0px;
#box_art{
position:absolute;
top:120px;
left:650px;
width:600px;
height:800px;
border: none;
padding: 0px;
margin: 0px;
visibility: hidden;
z-index: 50;
#close_button {
position:absolute;
width: 200px;
height: 200px;
top: -100px;
right: -100px;
background-image: url('icons/close_small.png');
z-index: 51;
display: block;
#play_button {
position:absolute;
width: 400px;
height: 200px;
bottom: 20px;
right: 100px;
background-image: url('icons/play.png');
#darkenScreenObject {
z-index: 40;
filter: alpha(opacity = 50);
background-Color: #000000;
top: 0px;
left: 0px;
width: 1900px;
height: 1014px;
display: block;
position: absolute;
#darkenScreenObject2 {
z-index: 60;
filter: alpha(opacity = 70);
top: 0px;
left: 0px;
width: 1900px;
height: 1014px;
display: block;
position: absolute;
#fade_div {
z-index: 900;
background-Color: #FFFFFF;
top: 0px;
right: 0px;
width: 1900px;
height: 1014px;
display: block;
position: absolute;
.popup {
border:solid black 1px;
font-family:Tahoma, Verdana, Arial, Helvetica, sans-serif;
font-size:36px;
color:#333333;
display:none;
position:absolute;
width:635px;
z-index:61;
.popuptitle {
background:#9f9385;
color:white;
font-size:34px;
height:30px;
padding:5px;
text-align:center;
.popupbody {
background:#FFFFE1;
font-size:34px;
padding:5px;
text-align:center;
#popup {
position:absolute;
top:250px;
left:600px;
width: 700px;
height: 300px;
z-index: 61;
#internet_div {
position: absolute;
top: 25px;
left: 313px;
height: 960px;
width: 1264px;
background-color: white;
#internetframe {
height: 960px;
width: 1264px;
#header{
position:absolute;
top:10px;
left:280px;
width:1600px;
height:300px;
z-index: 0;
#home{
position:absolute;
top:25px;
left:25px;
width:250px;
height:250px;
z-index: 0;
#8box{
position:absolute;
top:305px;
left:310px;
width:1280px;
height:640px;
border: none;
z-index: 0;
padding: 0px;
#6box{
position:absolute;
top:305px;
left:470px;
width:960px;
height:640px;
border: none;
z-index: 0;
padding: 0px;
#4box{
position:absolute;
top:305px;
left:630px;
width:640px;
height:640px;
border: none;
z-index: 0;
padding: 0px;
#2box{
position:absolute;
top:305px;
left:250px;
width:640px;
height:640px;
border: none;
z-index: 0;
padding: 0px;
#bigbox1{
position:absolute;
top:0px;
left:0px;
width:640px;
height:640px;
border: none;
padding: 0px;
margin: 0px;
#bigbox2{
position:absolute;
top:0px;
left:780px;
width:640px;
height:640px;
border: none;
padding: 0px;
margin: 0px;
#landingbutton1{
position:absolute;
top:305px;
left:170px;
width:705px;
height:350px;
border: none;
padding: 0px;
margin: 0px;
#landingbutton2{
position:absolute;
top:305px;
right:170px;
width:705px;
height:350px;
border: none;
padding: 0px;
margin: 0px;
#landingbutton3{
position:absolute;
top:660px;
left:170px;
width:705px;
height:350px;
border: none;
padding: 0px;
margin: 0px;
#landingbutton4{
position:absolute;
top:660px;
right:170px;
width:705px;
height:350px;
border: none;
padding: 0px;
margin: 0px;
#box1{
position:absolute;
top:0px;
left:0px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box2{
position:absolute;
top:0px;
left:320px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box3{
position:absolute;
top:0px;
left:640px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box4{
position:absolute;
top:0px;
left:960px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box5{
position:absolute;
top:320px;
left:0px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box6{
position:absolute;
top:320px;
left:320px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box7{
position:absolute;
top:320px;
left:640px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#box8{
position:absolute;
top:320px;
left:960px;
width:320px;
height:320px;
border: none;
padding: 0px;
margin: 0px;
#left_arrow{
position:absolute;
top:465px;
left:0px;
width:300px;
height:284px;
border: none;
padding: 0px;
margin: 0px;
#right_arrow{
position:absolute;
top:465px;
right:0px;
width:300px;
height:284px;
border: none;
padding: 0px;
margin: 0px;
#box_art{
position:absolute;
top:120px;
left:650px;
width:600px;
height:800px;
border: none;
padding: 0px;
margin: 0px;
visibility: hidden;
z-index: 50;
#close_button {
position:absolute;
width: 200px;
height: 200px;
top: -100px;
right: -100px;
z-index: 51;
display: block;
#play_button {
position:absolute;
width: 400px;
height: 200px;
bottom: 20px;
right: 100px;
z-index: 40;
top: 0px;
left: 0px;
width: 1900px;
height: 1014px;
display: block;
position: absolute;
z-index: 60;
top: 0px;
left: 0px;
width: 1900px;
height: 1014px;
display: block;
position: absolute;
#fade_div {
z-index: 900;
top: 0px;
right: 0px;
width: 1900px;
height: 1014px;
display: block;
position: absolute;
.popup {
font-size:36px;
color:#333333;
display:none;
position:absolute;
width:635px;
z-index:61;
.popuptitle {
background:#9f9385;
color:white;
font-size:34px;
height:30px;
padding:5px;
text-align:center;
.popupbody {
background:#FFFFE1;
font-size:34px;
padding:5px;
text-align:center;
#popup {
position:absolute;
top:250px;
left:600px;
width: 700px;
height: 300px;
z-index: 61;
#internet_div {
position: absolute;
top: 25px;
left: 313px;
height: 960px;
width: 1264px;
#internetframe {
height: 960px;
width: 1264px;
Try using PWB v2.11.8b from the Beta Downloads page and add either of following to your INI file.
EnableSecurityBand=False
or
LocalMachineLockdown=False
or
phillipbrickner
- Contributor
This fixed it:
You are always quick to fix any problems I have! Thanks Scott!
