PWB Takes About 1 Minute to Start When in SecureMode
wgragg
Post by wgragg »
In my progression of testing, I turned on Securemode in the ini file. Now it takes approximately 1 minute for PWB to start up.
Any ideas on that one?
Wendell
wgragg
Re: PWB Takes About 1 Minute to Start When in SecureMode
Post by wgragg »
Ok, I think I fixed it. I put in a Securemodedelaystart=2 and it started working correctly. Strange.
PWB v3.03.6 has the default set to 100 seconds if the setting is left blank. Setting it to 0 or less will disable the delay.
Starting with PWB v3.03.7 the default is to disable the delay.
waleed432
Spectator
Spectator
Post by waleed432 »
I am running Windows 7, 64bit.
I have installed the BETA for SETPWB (one mentioned for Vista, etc).
PWB will operate as the default browser in my admin profile but not a user profile (which is my goal).
Any suggestions?
You need to run SetPWB when logged in as the user.
