I need some ideas for troubleshooting a problem.
We are using PWB 3.0.3.4 on our catalog-only stations. The underlying browser is IE 9. We recently implemented a form on our web site that makes use of jQuery.validate. When I use my IE 9 browser and submit this form, the validation script is invoked. When I run PWB over this same IE 9 installation, the validation script is not invoked when I submit the form.
I know that the same problem occurs when IE 9 is in compatibility mode. But I've confirmed that the IEBrowserEmulation key does not exist in the pwb.ini file, and when I visit whatismybrowser.com in PWB it is reporting IE 9.
Does that ring any bells for someone? Is there logging or developer tools that I can invoke in PWB?
Thanks for any leads.
Need some troubleshooting pointers
Re: Need some troubleshooting pointers
Try adding the following to your INI file.
JavaScriptVoidCancelNavigate=False
PWB is set to cancel navigation when it encounters "javascript:void" type functions, the above setting will allow the navigation to continue.
Otherwise, what is the URL of the site with the issue?
Thanks for your quick reply.
I've discovered that the problem *does* occur with IE 9 and is not limited to PWB. So the issue is on my end.
Have a great weekend.
