Do these work with PWB3? I would really like to get away from the old engine for PWB2. Also how does Kiosk mode work and having to enter a password to close pwb? It also seems like Java is not working at all. Thanks
EDIT I might just be having problems in the chrome version. I will update with my findings.
URL redirect and PWBExecute
phillipbrickner
- Contributor
Re: URL redirect and PWBExecute
For the JavaScript, if you are using the PWB URL filters ensure you are allowing JavaScript by adding the following to your URL filter file.
+JavaScript
+About:Blank
The "PWBExecute" functionality is IE specific and will not work with the Chrome version of PWB.
+JavaScript
+About:Blank
phillipbrickner
- Contributor
Thanks. That was super fast!
I am also getting an active x security warning at top where I can right click and allow blocked content but I want it to automatically.
Also do re directs work with PWB3? I loved that add on for version2 it was really useful in bringing people back from sites like facebook and the likes.
The security warning is comping from Internet Explorer. Use the Control Panel applet Internet Options to allow for ActiveX controls.
Just so we are on the same page, which settings in the PWB v2 INI are you referring to in regards to the redirects? We can add this to our to do list for PWB v3 Basic.
phillipbrickner
- Contributor
Sorry I haven't replied I was tied up with another project.
Here is the code from pwb v2 it was under [Files].
CheckURLRedirectFile=C:\Program Files (x86)\TeamSoftware Solutions\Public Web Browser v2\URLDirect.txt
phillipbrickner
- Contributor
I am having some trouble still displaying a page that worked on ie9 and pwb2. It is a local page.
I attached a zip file with the local web page to see if it works with your pwb3.
- localpage.zip
- (2.38 KiB) Downloaded 1769 times
PWB v3 Basic does not have the Dynamic External Java Commands functionality of PWB v2.
JavaScript:window.external.PWBExecute
Since we incorporated the Chrome HTML rendering engine into PWB v3 which does not support this, the functionality was left out.
Scott...
Is this also true of the PWB v3.04.2 basic (IE) which uses the Internet Explorer Rendering Engine?
It is true PWB v3 current does not support the PWB v2 Dynamic External Java Commands functionality. PWB v3 IE and PWB v3 CEF share the same code base, just use different rendering engines.
It was never very popular so we did not include it. If there is enough demand we can add it to our to do list for PWB v3.
Starting with PWB Version 3.05.0 12-02-2016, the Dynamic External Java Commands are supported.
