Virtual Keyboard
atdirl
Virtual Keyboard
Post by atdirl »
Does the PWBv3 software work with a virtual keyboard in a touchscreen setup?
Re: Virtual Keyboard
As of version 3.03.9 it does.
atdirl
Post by atdirl »
Seems to work great until I test in the kiosk and cannot get the virtual keyboard to appear. What are the related settings for the virtual keyboard in the .ini file?
Also how can I check which version of PWB I'm using? My ini file has: IniFileVersion=3.00 and the download is PWBv3cef.
Kiosk and Secure mode will cover the soft keyboard so it will not be available, try using HideGUI instead.
To get the version number, see the About from the system menu (upper left hand corner) or right click on the PWB.EXE application file and select Properties.
