Hi all
We have just updated our catalogue computers from Windows 7 machines to brand new Windows 10 machines, and with the move, we have gone from PWBv2 to v3 IE. We (thought we had done thorough testing prior to rollout, but as it turns out, we have found a bad problem that has occurred as part of the upgrade.
We use Innovative's Encore for our catalogue. We had spent quite some time getting Encore to work with PWBv2, especially around logout and requesting of books as there is a javascript popup that was causing issues. This was operating nicely with Windows 7 and PWBv2, but our move to Windows 10 and v3 has brought this issue up again. Now, when we click the Request button, it starts to bring out the javascript popup window, but it only comes out about a 1/4 the way then completely disappears.
I have tested this on an old catalogue computer running Windows 7/IE9 and PWBv3.04.5 and 3.05 beta, and it works fine on this computer. I have installed PWBv3.04.5 and 3.05 beta and 3.04.5 CEF on my Windows 10 desktop, and I get the same thing happen as the new catalogue machine. Internet Explorer works fine with this.
Any ideas as to what could be causing this/how I can fix this? We are trying to avoid rolling back to PWBv2 as we need the use of tabbed browsing as we also have a booking room site on the catalogue computers also.
Thanks in advance
Rob
PWBv3 IE windows 10 not allowing a Javascript popup
Re: PWBv3 IE windows 10 not allowing a Javascript popup
It is actually a problem with Encore and Internet Explorer 11.
https://www.teamsoftwaresolutions.com/f ... 004&p=7259
Hi ScottScott wrote:It is actually a problem with Encore and Internet Explorer 11.
Thanks for that. Sorry I didn't see it before then. As we are using PWB 3.05 Beta so we can have resizable tabs and set focus tabs, we have gone with the IEBrowserEmulation workaround, and will hold off going to CEF until 3.05 is available.
Thanks again for your help with this
Cheers
Rob
northbayteky
- Provider
We just upgraded our online library card application and it doesn't display in the user profile but it does display in the admin profile.
https://ecard.snap.lib.ca.us/index.php?do=english
Is this related to the issues with IE11? Or do I need to make a change to the user profile?
If it displays in the admin profile and not the user profile it is most likely a Windows permission issue.
