For informaitonal purposes here is a list of DLLs that PWB loads when running including DLLs loaded by the IE HTML Rendering engine.
Loaded 'C:\WINDOWS\system32\ntdll.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\kernel32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\mpr.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\advapi32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\rpcrt4.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\user32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\gdi32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\winmm.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\comdlg32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\shlwapi.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\msvcrt.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\comctl32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\shell32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\winspool.drv', No symbols loaded.
Loaded 'C:\WINDOWS\system32\oledlg.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\ole32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\oleaut32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\urlmon.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\version.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\wsock32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\ws2_32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\ws2help.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\wininet.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\crypt32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\msasn1.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\oleacc.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\msvcp60.dll', Symbols loaded.
Loaded 'C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.10.0_x-ww_f7fb5805\comctl32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\riched32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\riched20.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\msctf.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\clbcatq.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\comres.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\shdocvw.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\secur32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\sxs.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\apphelp.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\msi.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\shdoclc.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\mlang.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\mswsock.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\rasapi32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\rasman.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\netapi32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\tapi32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\rtutils.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\wshtcpip.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\mslbui.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\sensapi.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\userenv.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\dnsapi.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\winrnr.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\wldap32.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\rasadhlp.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\mshtml.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\msimtf.dll', No symbols loaded.
Loaded 'C:\WINDOWS\ime\sptip.dll', No symbols loaded.
Loaded 'C:\WINDOWS\ime\spgrmr.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\jscript.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\uxtheme.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\iepeers.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\msls31.dll', No symbols loaded.
Loaded 'C:\WINDOWS\system32\mshtmled.dll', No symbols loaded.
DLLs used by PWB
Jscript links don't work
Hello all,
We're using the PWB2 now for a few days and I encountered
problems with links using javascript, they simple don't work
Is this a known issue? Is there a solution?
As an example you can check out this page:
http://www.veenendaal.nl
The links on top of the page are all using javascript and so don't work...
Any help would be greatly apriciated.
Respect,
Perry van den Brink - Admin @ OBVeenedaal.nl
admin@obveenendaal.nl
Respect,
Oops I forgot the reason why I replied to this subject;
I did a search on this board for "jscript" and so ended up with the above
listing and wondered if my problems could be related to
"C:\WINDOWS\system32\jscript.dll" ?
Respect,
Respect,
The above "Guest" was me;Anonymous wrote:Scott, thank you so muchScott wrote:Are you using the URL filter? If you are make sure you have +JavaScript and +About:Blank in your URL filter file.
Everything works like perfect now, great!
I was so happy the problem was solved I total forgot to put my name in here
Again, Thanks Scott
