Can't close PWB with Word doc
Perry
Post by Perry »
I found some weird problem last week;
When you open a Word document in PWB (through a website) you can't close the browser unles you go back to the previous page so the Word document isn't open anymore.
Is this a bug or do I have to change some setting?
I have tested closing a Word document with PWB v2.04 and PWB v2.10 using the stock INI file and it closes without trouble. So it is possibly a bug in the version of PWB you are using or a setting in your INI file. We can narrow down the problem if we know what version of PWB you are using.
Perry
Post by Perry »
We're using version 2, 1, 0, 1
EDIT:
I can send you our ini file if that helps?
Try upgrading to PWB v2.10.2. Simply download the PWB upgrade and copy the new EXE over the old EXE, no other changes need to be made. If this does not correct the problem, please send a copy of your INI file to support@teamsoftwaresolutions.com.
Perry
Post by Perry »
Thanks Scott, that problem is fixed now :)
