PWB v2.10.3 Released
Locked
PWB v2.10.3 has bee released and includes the following fixes changes and addtions.
Version 2.10.3 02-05-2008
Fixed/Changed:
Fixed HTTPS support in IP filter when -all is set.
Fixed Problem with Windows XP SP2 Security Feature loading.
Fixed Release document when clsoing PWB Windows with non-HTML document loaded.
Changed includes support for XP SP2 and IE7 advanced features and security.
Changed ignores About:Blank when [Browser]StartTimersOnMouseKeyboard=True
Changed UNC path INI files are copied to a temporary local file before parsing to speed loading.
Changed Scaling of image files in browser window with click to enlarge support.
Changed JAVA_PLUGIN_WEBCONTROL_ENABLE set to TRUE when starting.
Changed Exit script will run even if PWB is closed by overrides.
Changed About:Home to navigate to PWB home page instead of IE home page.
Added: (These settings are added but hidden until PWB v2.11 is released)
Added [Browser] MaximizeOnNonSizable=False Maximizes window when page sets non-resiable.
Added [Java] JavaClose= Closes PWB with bypass for disable exit and restart on close.
Added [Java] JavaStartApp= Starts application in new process.
Added [Files] ExecuteOnDenyAccess= Executes application with URL (%1), and access string (%2) as arguments.
Added [Files] ExecuteFilterFile= Filter file for CheckExecuteAccess execute on deny access.
Added [Security] CheckExecuteAccess=False Checks URL access and executes application.
Added [Browser] DisableImageSizing=False Disables image resizing when image file is bigger then window.
Removed:
[Java]JavaPrintFrame Not used often but causes problems with long URL addresses
[Java]JavaFillElement Not used often but causes problems with long URL addresses
Locked
