Screensavers and timers
joechummer
Post by joechummer »
I have both an inactivity timer and an activity timer set in PWB for a system intended to be used as an internet kiosk. However, whenever the warning messages for either timer come up, if I let Windows handle the the sreensaver (a custom .scr we've put together), the screensaver quits due to Windows interpreting the timer warning dialog boxes as user activity. As it is now, with both timers turned on (inactivity set at 5 mins, activity set at 10, set to warn at 8 and 9 mins), the screensaver, set to come up every 6 minutes (to avoid the inactivity timer kicking it off), triggers once, after the inactivity timer first goes off, and then is never able to trigger again.
Is there any way around this?
I'm assuming that setting up the Windows screensaver in PWB.ini would do the trick, but I can't seem to get PWB to open the Windows screensaver even though I put in the path to a legitimate .scr file, set the WindowsScreenSaverMinutes (anywhere from 1 to 5 minutes, just to see if it will kick on) and set EnableScreenSaver to True.
We need a bit more information to help answer your question.
What version of IE are you using?
What is your timer actvities set to?
InactivityAction=Home
ActivityAction=Exit
What is the URL your home page is set to?
What are your settings for all the screen saver keys?
[ScreenSaver]
EnableScreenSaver=False
ScreenSaverSeconds=1200
EnablePolicyScreenSaver=False
PolicyScreenSaverSeconds=10
DisableScreenSaverOnPolicyClose=False
DisableScreenSaverOnClose=False
WindowsScreenSaverExe=
WindowsScreenSaverMinutes=0
joechummer
I believe PWB is version 2.10.3. Using IE6 with WinXP SP2.
HomePage=http://www.daytondailynews.com
ActivityAction=Home
I did have the activity action as exit, but every once in awhile, closing PWB results in a "Do you want to report this error to Microsoft" crash, and won't reopen automatically upon close like PWB is supposed to, but this is a different issue entirely.
[ScreenSaver]
EnableScreenSaver=True
ScreenSaverSeconds=
WindowsScreenSaverExe=C:\WINDOWS\system32\ddn.scr
WindowsScreenSaverMinutes=1
The problem is that the home page has a refresh timer and PWB is interpreting this as user action and starting the PWB timers.
<meta http-equiv="refresh" content="900;url=/?r=t" />
Setting the following will tell PWB to start the timers only when there is mouse or keyboard activity.
StartTimersOnMouseKeyboard=True
You can further refine this with the following setting.
[Inactivity]
ResetOnMouseMove=False
These will allow you to use the normal Windows Screen Saver functionality.
There is a bug in PWB v2.10.3 that can cause PWB to crash if it is closed quickly after navigating to a site that loads slow. This has been corrected in PWB v2.10.4 currently in beta testing and available on the beta download page.
joechummer
For some reason, I set both of these:
[Inactivity]
and the inactivity timer's warning dialog still kicks out of the screensaver.
Please send a copy of your INI file to support@teamsoftwaresolutions.com.
This will allow us to simulate your setup and hopefully provide a solution.
joechummer
It seems the problem was that since PWB was set to be "AlwaysOnTop=True", the screensaver would start on top of PWB, and when the inactivity timer kicked on -- regardless of whether an inactivity warning was enabled or not, PWB would activate on top of the screensaver! If PWB is quit with the override, the screensaver still runs until the mouse is moved. To get around this, I set AlwaysOnTop to False, and the screen saver runs over everything regardless of how often the inactivity timer carries out its function.
Thanks for the assistance.
