Print background colors and images
Steven
Post by Steven »
When i tried to print a picture from a specific website the printout was mostly correct except for the fact that the actual picture was missing. All other info such as headers and a border for the picture was on the printed page.
I've found out that this was caused by the option "Print background colors and images" not being enabled in IE6. So now when I print the page from IE6 its 100% ok. But when I print the page from PWB its still missing the picture on the printout.
Doesn't PWB follows the settings from IE or should I enable this somewhere else ?
I'm using version 2.1.0.4 of PWB on a Windows 2003 Server with IE6
PWB simply sends the print request on to the underlying Internet Explorer.
The "Print background colors and images" is set on an individual basis per login via Internet Options or through a Group Policy.
You can also set the option via a PWB startup batch file by setting the following Windows Registry value.
http://ie7triage.spaces.live.com/blog/c ... !277.entry
If you want to make available the Internet Options, enable the PWB Shellbar and create a Shortcut to "inetcpl.cpl" in the PWB Shellbar folder.
