Modifying the toolbar
Kadie
Post by Kadie »
Is there a way to modify the toolbar structure to use two rows? I'd like to have a shell bar, but I'd like it to be on its own row so as not to need the >>.
In the toolbars section of the INI file set the Shellbar Break to true. This will add a break between the main toolbar and the shellbar, making the shellbar go to the second line of the rebar.
[ToolBars]
MenuBarGripper=True
ToolBarBreak=True
ToolBarGripper=True
ToolBarChevron=True
ShellBarBreak=True
ShellBarGripper=True
ShellBarChevron=True
AddressBarBreak=True
AddressBarGripper=True
MenuBarWidth=
ToolBarWidth=
ShellBarWidth=
AddressBarWidth=
GoButtonGripper=True
GoButtonBreak=False
AlignBottom=False
KioskBarScrollBy=40
AutoSizeButtons=False
ButtonTextRight=False
ToolBarIconHeight=
ToolBarIconWidth=
ShellButtonIconWidth=
ShellButtonIconHeight=
KioskToolBarIconHeight=
KioskToolBarIconWidth=
KioskBarButtonColor=
KioskBarBackGroundColor=
Kadie
Post by Kadie »
Thank you and I'm sorry. I should've read the explanation text file more closely. I made the assumption the break was the seperator line.
