Problem with Distance Learning Site
AnthonyM
Post by AnthonyM »
Patrons are having problems accessing a distance learning site from Farmingdale State College. The site is:
http://www.farmingdale.edu/
In the top right corner is a link drop down list. If you click on
'Angel Distance Learning'
Its supposed to open a popup with the a login prompt. If you go to
https://farmingdale.sln.suny.edu/
Directly it works fine. It works fine in IE. I can email the rest of my INI if you need it. Thanks.
[SecondWindow]
AlwaysOnTop=True
LimitCount=
DisableMinimizeButton=False
DisableMaximizeButton=False
DisableMoveWindow=False
DisableResizeWindow=False
DisableTitleBar=False
WindowHeight=
WindowWidth=
WindowTop=
WindowLeft=
NewPageAsHome=False
OpenInParentWindow=False
DisableUnrequested=False
StartOnDesktopMode=False
OpenDesktopModeLink=True
ShowTimers=False
ShellBarURLNewWindow=False
DisableCloseButton=False
ShowShellBar=True
StartMaximized=False
CloseChildrenOnClose=Flase
SecondWindowIndicator=(Secondary)
OpenInNewProcess=False
ShowAddressBar=True
ShowGoButton=True
ShowKioskBar=False
ShowToolBar=True
ShowMenuBar=True
ShowStatusBar=True
DisableShiftClick=False
OpenInFrame=
Using a stock INI file with PWB v2.10.5 the second window as indicated seems to work the same as in Internet Explorer.
Please send a copy your INI file as an attachment to support@teamsoftwaresolutions.com.
PWB v2.10.6 currently available on our Beta Download page will fix the issue you are experiencing.
austinstrickland
Post by austinstrickland »
I would also like to thank for the answer.
Directory of best distance learning Schools and Colleges
Jenny
Post by Jenny »
I am a student of Farmingdale State College and also facing this problem to accessing a distance learning site on IE but now I am using Firefox and there is no such a issue. I recommend you to use firefox.
johnricky
no rocket science solution!
Post by johnricky »
New version of Fire fox has in-built functions to fix such problems. I too had quite a few problems but ever since the emergence of Fire fox it seems as if the problem had never existed in the first place.
johnricky
Post by johnricky »
Reports suggest that websites related to education are always vulnerable to such problems. Some days traffic barge in hugely and some days it is not. That volatility seems to be the root cause. In future, some of the sophisticated explorer may also be not able to tackle this problem.
Regards
John Ricky
Education Consultant
AskForEducation.com - Best source for Online and Campus Education Schools and Programs
