registration number
fmltech
registration number
Post by fmltech »
I just purchased a site license for PWB a few weeks ago, and saved the INI file on a floppy. I just installed it on thirteen computers, and about half of them still say unregistered after copying the INI file with the license number already typed in. The other half - also using the same INI file - do not say unregistered in the title bar.
Check that the account has at least read access to the INI file.
Check that the shortcut should has the correct Start in folder listed.
Make sure the command line path is pointing to the correct INI file if you are specifying the INI in the command line.
