Denial dialog box size & access.rtf file
jsomerfield
Post by jsomerfield »
Hello,
I am using version 2.04 and have created an access.rtf file for use with the url deny dialog box. The text of the .rtf file cannot be read without using the scrollbar. Is there a way to increase the size of the box? I have looked through the available documentation and could not find anything to make this happen.
Any advise.
Jeff
The following settings will allow you to size the message dialogs.
[Dialogs]
MessageHeight=
MessageWidth=
jsomerfield
Thanks for that info. We upgraded to 2.10.7 and the access.rtf dialog box now opens without a scroll bar. One minor detail, the dialog box opens and sits at the bottom of the screen. Any way to get the box to appear in the middle of the screen?
Jeff.
It should be centering on the PWB window. Please send a copy of your INI file as an attchment to support@teamsoftwaresolutions.com so we can take a look at it.
