PWB default shell issues.
jsomerfield
Post by jsomerfield »
We were running 2.0.4 as our default shell. I upgraded everything to 2.10.7 and I am now getting errors accessing files. Can you tell me what changed with the default shell to the new version?
Jeff
Online
You should use the full path to the files PWB is not finding. The rason is when you use PWB as the shell, the starting folder may not be the PWB folder. Without the full path PWB may not be able to find the files.
