Inactivity timer and screensaver
pcdave
Post by pcdave »
I need to have an inactivity timer set to 90 secs. There will also be a screensaver running as well set to go off at 2mins.
I had the inactivity action set to 'restart'. This closed all open windows and returned me to the home page but also disabled the screen saver.
I changed it to 'home' and this left the screensaver running but any secondary windows that were opened stayed open.
How do I reset to the home page and close all secondary windows and keep the screensaver running?
Thank you,
David
You should be able to have PWB exit and restart and still have the screen saver run 2 minutes after the restart.
What is your home page in PWB set to?
In most cases similar to this, the home page is refreshing there by negating the screen saver as Windows sees this as user activity.
pcdave
Post by pcdave »
The inactivity timer was set for 90 secs
I had the screensaver set for 1 min
Home page set to www.google.com for testing purposes
Are you using PWB as the Windows shell?
pcdave
Post by pcdave »
No we are not using it as the shell
When PWB restarts is the timer running on the status bar, or does it start when you click a link?
