Default Save Type
ChrisHearns
Default Save Type
Post by ChrisHearns »
When patrons try to save a web page the default type is .mht
I want to force html complete as the default save type.
If they use .mht it generates an error at all times becauase apparently .mht needs outlook express which I removed it so craigslist email response links doesn't auto launch in outlook express, which was a whole other problem.
Basically how can I have the system default to html complete as the save type or remove .mht format eh drop down menu so html complete is forced as the default.
Another solution would be to add back the exact files from outlook express that .mht needs to save without actually installing outlook express. Any idea what files it needs? I'd prefer solution one, just forcing it to default to html.
Chris Hearns
Rochester Hills Public Library
christopher.hearns@rhpl.org
248 650 7128
PWB uses the IE save dialogs for the logged on user, so if can you default IE to MHT, PWB will also use MHT.
Try this:
Log on as the user, go to Windows Explorer... Tools... Folder Options... View... under the "Managing pairs of
Web pages and folders", set "show and manage pair as a single file."
ChrisHearns
Actually, the default for IE is MHT. I want to get rid of MHT. How do I change the default to something else. The setting you listed below is already set and changing it to one of the other two options doesn't affect IE from defaulting to MHT.
Chris,
After more research it appears there is no way to default the save as file type when saving web pages in IE.
In fact if you save as a differetn type other then MHT, then save again IE defaults back to MHT. So it seems IE insists on saving in this format.
ChrisHearns
Do you have any idea how to find out what files MHT needs from outlook express to successfully save. Since I removed outlook to solve another issue, I can add back just the files that MHT needs, but I have no idea how to figure out which ones are needed.
Chris,
In researching this I remember seeing one reference to a DLL that comes with Outlook Express that was needed to save as MHT type files. I will look again and see if I can find it and post it here.
The DLL is "Inetcomm.dll" which is installed with Outlook Express.
Reference:
http://support.microsoft.com/kb/221787
ChrisHearns
Solution
Doesn't appear to be inetcomm.dll
But I did find the dll that would restore the MHT functionality.
Just for anyone else with the same problem in the future here it is.
It was MSOERT2.dll
Chris,
