Updating the PWB INI file
The Public Web Browser site license is a subscription based registration. The registration number has the date encoded into it so you will need to update the registration number in the INI file before your current license expires. When you receive your new registration number, there are a variety of ways to update the registration number in the INI file depending on how you have implemented PWB and how your network is arranged.
The easiest way is to "push" a new INI file through the hidden Windows Administrative share (C$) on Windows NT/XP.
You can use the Auto Register online system that allows us to assign you a permanent customer number that will automatically update your registration number. The Auto Register system is available in PWB v2.09 or newer.
The PWB INI file can be shared for all your computers from a file server. This makes updating easily done from a single location.
You can enabled the "JavaRegister" Dynamic External Java Command in the INI file. This will allow you to update the registration number through a JavaScript on a web page.
PWB Register: A console application that can be run in a PWB Startup script or a Windows logon script.
http://www.teamsoftwaresolutions.com/fi ... gister.zip
