Hi all;
I have a divx reader with hard disk connected by a wireless network to my PC: while I was renaming some folders the network went down and the folders become files, so now are unreadable.
Now, when I connect the network drive, in the left column I have 8 folders (instead of the 10 that I had before) and two files of 0kb.
Before this problem these two files were two folders containing hundreds of files.
How can I restore them? remember that I don't have a physical access to the drive, only by network.
Thank you
__________________
Ever seen gift idea like these? (idee regalo on italian, geschenkidee on german or cadeau original on french)
													Damaged files
				Tancredi76
 - Spectator
 - Contact:
Damaged files
				chrisadam2
 - Observer
Damaged files
The program will attempt to recover every readable piece of a file and put the pieces together. Using this method most types of files can be made useable even if some parts were not recoverable in the end!
