Override Command Section Question
GChan310
Post by GChan310 »
What is the syntax for the Override command section?
for example in the ini file there is
ShowAddressBar =
What do I put there to activate it?
If I wanted it to be Ctrl Alt Shift + ES how would I phrase it?
The overrides are case sensitive keywords typed into the PWB override dialog box. The override dialog box is accessed by hitting Ctrl-Alt-Shift+Insert.
