need help and guide to using a server based url.txt
jperito
Post by jperito »
Hi all,
I can't seem to get the url.txt to host on a server for pwb. I have database machines that need to use that url.txt to whitelist database sites and I would love to be able to update one file and have them all use the same info. How do i go about doing this? Is it possible?? Help
Try using the UNC path to the server file in the INI file.
CheckURLFile=\\server\share\folder\URL.txt
jperito
Post by jperito »
Thanks Scott
Worked like a charm!!!! :)
You should also have the following set in your INI file.
CacheFilterFiles=True
This will ensure the best performance.
