display settings on PWB 2
akola
Post by akola »
We updated to PWB 2.11 but when running IE 7 / IE 8 address of our library hides some of the links on the home page.
as you can see on the image our library address is blocking a link.
is there a way to change some settings so it goes down.. we tried with IE 6 and it works fine
its just IE 7 and IE 8 we are having problem.
print preview shows up the link but one can see address mixing with URL.
thank you
image in the next post
akola
Post by akola »
[/img]
As PWB uses whatever version of IE you have installed on the computer to render the HTML on the web page, check the web site with IE7 or IE8, do you get the same results?
What is the URL of the page having the issue?
akola
Post by akola »
thank you... same result with IE 7 and 8 so I guess problem with my webpage..
ty
You are welcome.
