Problem with Expedia web site
amutch
Post by amutch »
From the home page of Expedia.com, do a search for flights. When you click on the "Search for Flights" button, you get an "about:blank" pop-up window and nothing shows up on the main page. What should happen is that the pop-up should show an ad and the main window shows an "intermediary" searching message before displaying the results. When tested with IE, it works as expected.
PWB 2.11.5
IE 9.0.8112
Windows 7 with SP1
PWB version 2.11.6 available on the Bet Downloads page should correct the issue.
You will either need to revert back to version 2.11.4 or use 2.11.6 to correct the issue.
Please note version 2.11.6 is on the fast track to be released because version 2.11.5 has the popup issue.
amutch
Post by amutch »
Thanks. I'll give that a try.
amutch
Post by amutch »
That fixed the problem with the Expedia site.
amutch
Post by amutch »
BTW - The new beta reports itself as 2.11.7 in the "About".
We were a bit ahead of ourselves.
PWB version 2.11.6 has been officially released.
amutch
Post by amutch »
I'm not seeing that on the download page.
Sorry, we posted the new version so the links are working, but the web site did not update correctly.
It is fixed now.
amutch
Post by amutch »
Was able to download and install the new release. Thanks.
