Alt F4
Jreinard
Alt F4
Post by Jreinard »
I have
[Overrides]
ExitBrowser=password
set in my INI.
I can use control alt shift insert and the password dialog appears.
but on the same window if I press alt F4 PWB just closes, it does not prompt for the exit broswer password.
Jesse
Did you set the following?
DisableExit=True
The "[Overrides]ExitBrowser" keyword is entered into the dialog show when the Ctrl-Alt-Shift + Inset is pressed.
Jreinard
Post by Jreinard »
No I wasn't I'll give it a try.
Edit: Yep, it works. Thanks again!
