Alt F4
Posted: Tue Jul 31, 2012 9:28 am
by Jreinard
I have
[Overrides]
ExitBrowser=password
set in my INI.
I can use control alt shift insert and the password dialog appears.
but on the same window if I press alt F4 PWB just closes, it does not prompt for the exit broswer password.
Jesse
Posted: Tue Jul 31, 2012 1:54 pm
Did you set the following?
DisableExit=True
The "[Overrides]ExitBrowser" keyword is entered into the dialog show when the Ctrl-Alt-Shift + Inset is pressed.
Posted: Wed Aug 01, 2012 6:53 am
by Jreinard
No I wasn't I'll give it a try.
Edit: Yep, it works. Thanks again!
