Links No Longer Work After Internal DNS Changes - Ideas?
cceller
Post by cceller »
I am writing from a public library.
We use PWB to run our catalog machines.
Yesterday everything was running just fine. The web server that hosts the catalog is internal. We made inside DNS changes today as the domain changed.
Now, none of the links of the catalog page WITHIN the confines of PWB. On the same machine, with IE, evrything works.
Ideas?
Thanks - Chad
Chad Eller, MLS
Digital Services Coordinator / ILS Administrator
Gaston County Public Library
If you are using either of the PWB filters you may need to adjust them.
Also make sure if you have a Proxy server set in the INI file it is still valid.
