[ContextMenu] value: MenuBack
Jreinard
Post by Jreinard »
Hi, Scott. We noticed the default PWB.ini setting for
[ContextMenu]
MenuBack=True
should read simply
[ContextMenu]
Back=True
We were playing with the context menu and found that changing MenuBack had no effect, so on a hunch we deleted the word 'Menu' from the value and it worked. Thought you should know, and thanks.
-Jesse
You are correct, thank you. It will be corrected in the INI in the next release.
