Problems with Google Drive in PWB 2.11.7
smessick
Post by smessick »
I am testing out a new computer configuration to upgrade our public computers from XP to Windows 7. I'm using PWB 2.11.7. When trying to open or create a document in Google Drive, a dialog box “Message from webpage” pops up with the message “This error has been reported to Google and we’ll look into it as soon as possible. Please reload this page to continue.” Click the OK or Cancel button causes the dialog box to pop up again. Closing the window is the only way to proceed. This behavior does not occur when opening a spreadsheet or presentation; both work correctly. The problem does not occur in IE9.
For test purposes I’m logged in with administrative privileges. I’m using the default INI file except RestrictFileDownload is set to False under Security.
Re: Problems with Google Drive in PWB 2.11.7
The error is being caused by a setting added to beta versions of PWB v2.11.5e, and PWB v3.03.0 on 09-19-2012. You can use a previous version of PWB or add the following setting to your INI file.
JavaScriptVoidCancelNavigate=False
smessick
Post by smessick »
Thanks! That seems to do the trick.
