History File
Stareagle
History File
Post by Stareagle »
Hi
I set everything up for saving to a history file but it doesn't seem to be creating the file....
HistoryFile=History.txt
StationEnvironmentVariable=LIBOPCVMV
UseUniqueHistoryFiles=False
WriteHistoryFile=True
TrackURL=True
CheckURLAccess=True
ShowAccessDialog=True
LogAccess=True
ClearCacheOnClose=True
DisableContextMenu=True
UseCustomContextMenu=True
Any help would be appreciated
Stareagle
Re: History File
What is the folder you are running PWB from? You have PWB writing the History file to the PWB folder, if you are using the Program Files folder, this folder is read only for the user, even if the user is an Administrator.
Stareagle
Re: History File
Post by Stareagle »
I am using the pwb folder C:\ pwb
Stareagle
Re: History File
Try changing the INI file to include the full path to the history file.
HistoryFile=C:\PWB\History.txt
