javascript & popup windows
pwbegvpl
Post by pwbegvpl »
We are having a problem getting PWB to open or allow popup windows that are opened using javascript.
This is PWB 2.0.3.0 and we are running it in kiosk mode. Testing indicates that javascript itself is working correctly except for starting secondary windows.
Any suggestions on what to look at to debug the problem?
Add "+JavaScript" to your URL filter file.
Make sure you do not have pop-up windows disabled. You need to have the following settings in the INI to allow pop ups.
DisableNewWindow=False
[SecondWindow]
LimitCount=
OpenInParentWindow=False
DisableUnrequested=False
pwbegvpl
Post by pwbegvpl »
We got the popup window to open but now there is no way to close it, move it, resize it or do anything else with it. I tried changing the [second window] for
DisableMinimizeButton=False
DisableMaximizeButton=False
DisableMoveWindow=False
but that hasn't worked. The only way to get the second window gone is to log off.
