History File Token Code
Here is a list of the codes PWB uses in the history file.
<-> Normal, URL entered in Address box
<p> Page Printed
<e> PWB error occurred
<t> URL Tracking, TrackURL=True
<a> Access logging, LogAccess=True
<a-> Access string was denied
<a+> Access string was allowed
<a;> Access string was not found
<ad> Pop-up closed, ClosePopupAds=True
<d> Access string denied, LogDeniedAccess=True
<ur> Pop-up closed, DisableUnrequested=True
<a=> Execute Access allow download
<a#> Execute Access navigate to file
<a!> Execute Access open in application specified
The history file has many levels at which it writes so you can control the amount of information that is written.
HistoryFile=History.txt
Enables History file and writes all URLs entered in the Address bar.
LogAccess=True <a-> <a+> <a;> <ad>
Causes PWB to write to the history file when access for the IP, URL, and POPUP, filters are used.
<ad> Popup ad is being checked
TrackURL=True <t>
Causes PWB to write to the history file when any URL is browsed to.
CheckURLAccess=False
CheckIPAccess=False
ClosePopupAds=False
Used with log access if the history file is enabled.
To limit the history file, you should have TrackURL and LogAccess set to False.
Jaysun
Post by Jaysun »
What does <a*> mean in the history file?
Jason
Jason Weinstein
Eugene Public Library
Eugene, OR
The "<a*>" means PWB check for access on the URL and did not find any matching strings in the filter file so it is taking the default action supplied in either the "+all" or "-all" option.
timh
Re: History File Token Code
Post by timh »
... and <d> ? (which always seems to follow an <a*> for the same URL in my logs).
Tim
Tim,
The information has been updated.
boby
Post by boby »
Run administration activity reports...these will show when serial number was assigned to userid.
Get the latest home decor ideas and crafting tips. Buy best home decoration & kitchen accessories, bathroom accessories online here.
