minimize, maximize, exit
gene
Post by gene »
Sorry this is such a simple question, but what setting controls showing the minimize/maximize/exit buttons on the top right of the screen.
I allow a second window to be opened, and they feature these buttons but not the original browser window.
How can I correct this to show these three buttons. Currently, I can choose File>Exit, but I would prefer these buttons to show as well.
Gene
For the primary window those would be...
DisableMinimizeButton=False
DisableMaximizeButton=False
DisableCloseButton=False
hello,
thanks but they are all set this way and therefore should show accordingly. Is there any other setting that could 'override' this setting.
I haven't changed a great deal in 'group policy' but is there a setting that i should be wary of or anything like that?
Gene
Do you have kiosk mode enabled?
KioskMode=False
In kiosk mode, the title bar is not displayed, and neither are the buttons to min/max/close.
or
ShowTitleBar=True
If that's set to false I think it will hide the title bar (but should still show those buttons, I believe)
gene
Post by gene »
that did the trick.
thanks!
Alachua
Post by Alachua »
I have the same problem here. I had to turn KioskMode back on because, When I turn it off I get the First FULL Screen with a CAN NOT DISPLAY THIS PAGE error on it. Then the Second screen comes up just fine. If I exit out of the second screen their is no way to close the First screen with out using Task Manager to cancle it.
I checked the Following to make sure they were set right.
KioskMode=False
DesktopMode=True
ShowTitleBar=True
Im sure I am missing somthing else. Any Ideas? :evil:
Set desktop mode to false.
Alachua
Post by Alachua »
Thanks Scott,
That was the one I kept missing.
Every thing is working A-Ok now.
:D
