PWB 10 and 11 .inis
jfrasier
PWB 10 and 11 .inis
Post by jfrasier »
Almost all of our computers that are running PWB are on version 10. A few are on version 11.
The ones on 10 are getting a message 'do you want to debug this webpage?' The few that are running version 11 are not getting that error. I see that the .ini that came with version 11 has a lot more lines. Can I just use it for the version 10 computers, or can I copy a line or 2 or a block of lines from 11 to 10?
Jane
Re: PWB 10 and 11 .inis
Update one of the 2.10 INI files to 2.11 with the INI Editor. Then you can distribute the update INI file along with the new PWB.EXE file.
Here is more information.
http://www.teamsoftwaresolutions.com/fo ... ?f=1&t=709
You could also use your current 2.11 INI and copy this with the PWB 2.11 EXE file.
jfrasier
Post by jfrasier »
I use one .ini on a network share. I wasn't planning to update all the PWB.exe's in the libraries around the county. Can I just use a pwb.ini that is working fine for an 11 pwb.exe installation?
You can use the 2.11 INI with PWB 2.10 as long as you set the following.
DisableINIVersionCheck=True
jfrasier
Post by jfrasier »
Thanks. I will check that out on Monday.
Jane :)
