2.04 ini file
2.04 ini file
Is the ini the same for 2.04r3 and r4 ?
The INI should be exactly the same as for v2.04rX
I think that the operative word is "should"...
I am running the previous 2.04 version with it's ini file, and I have
ShowInactivityTimer=True set, but if I run this ini with r4 the timer does not display, the inactivitytimer is active and functional, but the timer does not display. If I switch back to the previous exe it displays correctly.
It could be R4.
I said should because revision 4 is still in beta testing. I will take a look at it and see where the problem is.
Can you send a copy of your INI file to Support@TeamSoftwareSolutions.com? I can not seem to duplicate the problem with the timers not showing up.
I had modified how the timers are displayed, and mistakenly disabled displaying them when the show status bar time was disabled. It is fixed now.
http://www.teamsoftwaresolutions.com/beta/PWBv204r4.zip
