Blank page on specific link click
towenDPL
Post by towenDPL »
We seem to be having a javascript issue, where when a patron clicks a particular link it generates a blank page.
The issue can be seen here, when clicking on the "classic catalog" link in the left column
http://dpl-encore.deerfieldlibrary.org/ ... kCFmMashcY
I have added +JavaScript and +about.Blank into URL.txt, otherwise this is on a completely clean install.
The link works fine on the same machines using either Chrome or Internet Explorer
Thank you!
Re: Blank page on specific link click
What version of PWB are you using including the minor revision number, for example 2.11.8?
towenDPL
Post by towenDPL »
We have two sets of machines running PWB, one is running 2.11.8 and one is running 2.11.6 with both experiencing the same issue.
I also have 2.11.8 on my personal machine for testing purposes and have tried in 3.03.6 as well.
Setting the following in your INI file should correct the issue.
DisableNewWindowInit=True
towenDPL
Post by towenDPL »
That did the trick, thanks!
