Inactivity timer and 2.4r4
Morgyne
Post by Morgyne »
Has anyone experienced problems with the inactivity timer not working
in this release? I have the following in the .ini file and it doesn't work.
[Inactivity]
InactivityTimer=True
I have also turned on the activity timer but to no avail. Does the
time display in the status bar have to be enabled in order for it to work?
Am I missing another place in the ini file to turn on the timer?
TIA
Morgyne
The timers seem to act as expected on my test machines.
Are you using the newest beta?
What version of Windows and Internet Explorer are you using?
Morgyne
Post by Morgyne »
I am using Windows 2K Professional an IE 6 SP1 with all the patches
I am using version 2.4R4 Public browser
I did however get it to work and display with this setting:
ShowStatusBarTime=True
Thanks for all the help.
Morgyne
I just double checked the setting and the timer seems to work with the show status bar time set to false.
Are you sure you are not still using a beta copy? This can be checked by looking at the Help About dialog, the word "beta" should not appear by the version number.
It may be helpful if you could send a copy your INI file that has the problem so we can fix the bug to Support@TeamSoftwareSolutions.com.
What do you have the activity and inactivity actions set to?
It is set to exit after 30 minutes along with the restartonclose set
to true.
I don't use the activity timer at this time, just the inactivity timer.
But since it works with the time display set to true it isn't as important
as other things I have on my plate. My apologies to all who have
answered my questions and the lateness of my responses. :oops:
Morgyne
