Problems with java applet in PWB 2.0
kohlas@slf.ch
Post by kohlas@slf.ch »
Our problem is that a java applet is not executed correctly in PWB 2.0 in kiosk mode. When we run it in the underlying Internet Explorer (version 6.0.2600.000), it works perfectly!
Our java applet needs to run on the SUN Java virtual machine (we have version 1.4.2.01) rather than the Microsoft VM. In the "Internet options" menu of the IE, we hence have activated Java (Sun) and deactivated the Microsoft VM.
I don't know whether
a) PWB is not able to run Java applets at all or
b) PWB automatically run applets on the Microsoft VM.
How can we force PWB to run applets on the Sun VM?
Your help is very appreciated, we need the applet soon in an exposition.
Best regards
Reto Kohlas
I would suspect if it runs fine in IE on the same system, the kiosk mode is causing the problem. Have you tried the Java app with PWB not in kiosk mode?
Is there a way we can access the Java application to test it? Feel free to email us at Support@TeamSoftwareSolutions.com.
