I'm having some problems with the shell buttons. I know they work, because it will launch Editor, but for the others I make, it just kills PWB. I tried the same thing with another setup, and it froze the software instead. Am I doing something terribly wrong?
[Button1]
Caption=Editor
ToolTip=Editor
CommandLine=c:\progra~1\Editor\Editor.exe
;WorkingDirectory=
[Button3]
Caption=Databases
ToolTip=Databases
CommandLine=c:\databases\databases.html
;WorkingDirectory=
ImageEnabled=C:\Program Files\PublicBrowser\WorldRotate.bmp
ImageDisabled=C:\Program Files\PublicBrowser\WorldRotate.bmp
ImageHot=C:\Program Files\PublicBrowser\WorldRotate.bmp
Jesse
shell buttons kill PWB
unfortunately not...
Thanks for the assist. It doesn't seem to have solved the problem, though.
The full button text of the file is this:
[Button1]
Caption=Editor
ToolTip=Editor
;WorkingDirectory=
[Button2]
Caption=Lytle
ToolTip=Lytle
CommandLine=c:\LytleCD\lytlecd.qi1
;WorkingDirectory=
[Button3]
Caption=Databases
ToolTip=Databases
;WorkingDirectory=
ImageEnabled="C:\progra~1\PublicBrowser\WorldRotate.bmp"
ImageDisabled="C:\progra~1\PublicBrowser\WorldRotate.bmp"
ImageHot="C:\progra~1\PublicBrowser\WorldRotate.bmp"
For button 2, the directory is under 8 chars and there are no spaces, but it has the same problem...
Jesse
[Button1]
Caption=Editor
ToolTip=Editor
;WorkingDirectory=
[Button2]
Caption=Lytle
ToolTip=Lytle
;WorkingDirectory=
[Button3]
Caption=Databases
ToolTip=Databases
;WorkingDirectory=
Jesse
PWB v1 can only launch executables through the shell buttons. PWB v1 can not launch a browser to a HTML page, and can not launch an application when pointed to a file that is associated with it.
You can point the shell button to a batch file that runs the application to open the file.
For example:
[Button3]
Caption=Test
Tooltip=Launch from a batch file
CommandLine=D:\Launch.cmd
Batch File:
REM Start notepad to open file
start notepad d:\subclass.txt
PWB v2 can open any file with the associate application and is easier to use since you only need to create a Windows shortcut and copy it to the shell bar folder.
For example:
[Button3]
Caption=Test
Batch File:
