Policy File
jwurian
Policy File
Post by jwurian »
I am running PWB v3 in Windows 7. OpenDNS reports that the Policy.html file will not load. ShowPolicyDialog is set to true. I also tried Policy.txt with the same result. What am I doing wrong?
John W. Urian
Information Technology Librarian
Hood College - Beneficial-Hodson Library
401 Rosemont Avenue
Frederick MD 21701-8575
urian@hood.edu
Re: Policy File
What do you have for the following setting in your INI file?
PolicyFile=
jwurian
Re: Policy File
Post by jwurian »
Policy.html
John W. Urian
401 Rosemont Avenue
urian@hood.edu
Re: Policy File
Then PWB is using the local file. Ensure there is a file called "policy.html" in the PWB folder.
If you still get the error, set the full path in the INI file.
For example:
PolicyFile=C:\PWB\policy.html
jwurian
Re: Policy File
Post by jwurian »
The full path works. Thanks.
John W. Urian
401 Rosemont Avenue
urian@hood.edu
