v3.03.7 beta w/ CEF crash on timeout?
ntgreg
Post by ntgreg »
Hello,
We've been testing the 3.03.7 beta w/ CEF, and I have found (on 2 different machines) that when the activity timer reaches 0, and the final warning message expires, PWB crashes.
Is this a known bug w/ the beta?
Re: v3.03.7 beta w/ CEF crash on timeout?
This is not a known bug, but thank you for reporting it.
What is the error message you are getting?
What do you have the following set to?
[Activity]
ActivityTimer=True
ActivitySeconds=10
ActivityMessageFile=activity.html
ActivityAction=Exit
ActivityWarnAt=
ActivityWarnMessageFile=
ActivityStartOnOpen=FALSE
ActivitySecondWarnAt=
ActivitySecondWarnMessageFile=
ntgreg
Re: v3.03.7 beta w/ CEF crash on inactivity timeout?
Post by ntgreg »
First, thanks for the quick reply!
Second, I mis-reported in initial post; the issue is on the inacitivity timer, not the activity timer (my apologies...I've updated thread subject accordingly!)
Here are the settings I have (pretty much the default):
[Inactivity]
InactivityTimer=True
InactivitySeconds=20
InactivityMessageFile=Inactivity.html
InactivityAction=Home
InactivityStartOnOpen=False
InactivityShowDialog=True
ResetOnMouseMove=True
ResetOnMouseButton=True
ResetOnKeyboard=True
Error info from the Windows event log:
Faulting application name: PWB.exe, version: 3.0.3.7, time stamp: 0x533c493f
Faulting module name: PWB.exe, version: 3.0.3.7, time stamp: 0x533c493f
Exception code: 0xc0000005
Fault offset: 0x0007c874
Faulting process id: 0xdd4
Faulting application start time: 0x01cf5835e42bf4a5
Faulting application path: C:\Users\gwilliams\Desktop\PWBv3037cefC\PWB.exe
Faulting module path: C:\Users\gwilliams\Desktop\PWBv3037cefC\PWB.exe
Report Id: 3d9cf77a-c429-11e3-af03-90b11c758d0c
Thank you.
The bug is now fixed in version "PWBv3037cefD" currently available on the Beta Downloads page.
A better option instead of "InactivityAction=Home" is to use the "InactivityAction=Exit" with "[Security]ClearCacheOnClose=True" and "[Security]RestartonClose=True". This gives each new patron a fresh browser.
