PWB v3 CEF and Gmail
jlegree
Post by jlegree »
Is there a way to configure PWB v3 CEF to delete cookies at closing? We're running into users logging in to Gmail and finding a previous user's name and email address in the login box. Is incognito mode an option with PWB v3?
Re: PWB v3 CEF and Gmail
We are looking into why PWB CEF is not clearing the cookies and cache with the following setting.
ClearCacheOnClose=True
In the meantime you can use the PWB startup script to clear the cache and cookies with the following steps.
1. Create a batch file, for example "clean.cmd" in the PWB folder.
2. Set the PWB startup script to run the batch file when it starts with the following example.
INI setting:
StartupScript=C:\PWB3\clean.cmd
Batch file:
rd %TEMP%\cache /s /q
When PWB starts it will run the "clean.cmd" batch file which uses the "rd" command to remove the directory PWB v3 CEF is using for caching.
jlegree
Post by jlegree »
That does the trick! Thanks Scott!
Jon.
Please note, PWB v3.04.2 CEF Release Candidate 1 now available on the Downloads page fixes the Clear Cache on Close in PWB v3 CEF.
timh
Post by timh »
Did this problem creep back in?
With
[Security]ClearCacheOnClose=True
in both PWB CEF 3.05.0 beta K and in the latest RC2 I am finding visited links still displayed in the different color after a PWB close and restart, and looking at %TEMP%\Cache it still seems to be populated after PWB is closed?
Tim.
Thank you. We'll check into it.
PWB 3.05.0 CEF RC4 now available on the Beta Downloads page now clears the cache when PWB starts preventing file in use when PWB us exiting.
