DisableMoveWindow not working and new eLog button....
MasseyRob
Post by MasseyRob »
Hi all
I was wondering if anyone else has had any issues with 2.11.x and the DisableMoveWindow feature? I have this set to true in the ini file, but users are able to move the window initially which takes it from being maximised to being about half size, and when once they release the mouse after moving the window, then it won't allow users to move the window (I hope that makes sense).
I was hoping that the latest version available (2.11.9) would fix this, but alas, no. Is there any way to fix this so users cannot move the window? This happens both if I am running PWB via a startup delayer shell or in windows natively.
Also, I have found that 2.11.9 now has an elog button, but I cannot see where I can remove it from in the ini file. Can you please tell me what line I have to add to the ini file so I can remove this from the button bar?
Thanks in advance
Rob
Re: DisableMoveWindow not working and new eLog button....
To prevent the Window from being moved you need to disable the Windows Snap feature
http://www.teamsoftwaresolutions.com/fo ... f=8&t=2996
http://windows.microsoft.com/en-us/wind ... -on-or-off
See the following to remove the elog button.
http://www.teamsoftwaresolutions.com/fo ... php?t=1411
MasseyRob
Post by MasseyRob »
Scott wrote:To prevent the Window from being moved you need to disable the Windows Snap feature
Hi Scott
Perfect!! Thanks for the tips. PWB is now working exactly as expected.
Cheers
Rob
