Automatic Filter Generation
AlanM
Post by AlanM »
Since it can at times be challenging to add filters that are precise, I've written a vbs script to help automate the process. I've attached a .zip file containing the script, sample input/output files, and some documentation. Use at your own enjoyment/risk.
The reason for the challenge is that a generic filter entry like this...
+example.us
...will [probably incorrectly] match things like:
http://flexample.us
http://google.com?whatever=example.us
http://example.usx
Tightening up the filter to prevent such incorrect matches requires some effort and complicates maintenance and readability of the URL.txt file.
This script takes a fairly simple-looking filter input (in a file called PreURL.txt) and creates an output file (PostURL.txt) with the expanded filters that can be used directly by PWB. For instance:
Suppose you want to allow PWB to accept URLs from any page in the domain 'example.com'
In PreURL.txt, this entry will appear thusly:
*example.com
After PreFilter.vbs runs, this one line will turn into the following in PostURL.txt:
+^(https?://example\.com/)
+^(https?://example\.com/?)$
+^(https?://[A-Za-z0-9\.\-]+\.example\.com/)
+^(https?://[A-Za-z0-9\.\-]+\.example\.com/?)$
If you find problems or have feature requests, I can supply very limited support on this thread.
PreFilter-0.2.zip
PreFilter.vbs and documentation
(5.04 KiB) Downloaded 3861 times
