Error: Getting App Handle disabling Second Instance
USNA88
Post by USNA88 »
I'm getting an error when I try to launch PWB (CEF) in "secure mode." All I have to do to induce the error is simply set SecureMode=True. No other configuration changes, although I'll add the error occurs with my completely configured PWB.INI file as well. Anyway, this is the error message:
The error occurs in a pop-up that I can close and my system returns to normal. If I set SecureMode=False, PWB will start up just fine ... just not in the secure mode I need. *smile*
I'm running Windows 10 (Enterprise), if that matters.
Any suggestions?
Chris
Re: Error: Getting App Handle disabling Second Instance
When running PWB in secure mode PWB starts a second instance of itself in an alternate Windows Desktop.
To prevent the second instance error set the following in your PWB INI file.
DisableSecondInstance=False
johnnys
Post by johnnys »
I'm also receiving this, Win7, PWB v3.04.4 basic (CEF).
Only config I have on is SecureMode=True
I have set the following as suggested;
Did the setting fix the issue for you?
In the next version of PWB setting secure mode will turn off the second instance by default.
johnnys
Post by johnnys »
No, unfortunately it didn't fix it for me. Issue still here.
Sorry, that should have been the following setting.
It has been corrected in the previous posts.
jqjansse
Location: Vrije Universiteit Brussel, Brussels, Belgium
Post by jqjansse »
[quote="Scott"]Sorry, that should have been the following setting.
[[b]Security[/b]]
--Scott[/quote]
Dear Scott,
I am trying to "emulate" the DesktopMode=TRUE setting used in the PWB v. 2.x environment using the SecureMode=True setting in PWB v. 3.x in Windows 7/IE11 and I get the same error user USNA88 mentioned, even after setting DisableSecondInstance=False. Exactly the same behaviour user johnnys experienced. This occurs under Windows 7 Enterprise and under Windows Thin PC using the Original PWB.INI with only the SecureMode and DisableSecondInstance settings adapted.
What am I / are we missing?
Thanks in advance for your help.
Regards,
Jan J.
Jan Janssens
Universiteitsbibliotheek / University Library
Vrije Universiteit Brussel / Brussels Free University
Pleinlaan 2
B-1050 Brussel
BELGIUM
Did you move the setting from the [Browser] section to the [Security] section in the INI file?
jqjansse
Post by jqjansse »
[quote="Scott"]Did you move the setting from the [Browser] section to the [Security] section in the INI file?
[[b]Security[/b]]
--Scott[/quote]
Dear Scott,
that did the trick! Thanks for pointing this out.
Regards,
Jan.
Jan Janssens
Pleinlaan 2
B-1050 Brussel
BELGIUM
