Flash not working with Internet Explorer 11 in PWB
Rockhard
Post by Rockhard »
I am PWB 3.0.4.2. We have the same PWB running on multiple devices. However on the devices running Internet Explorer 11 it is not displaying Flash images. Using the exact same PWB on other devices with IE10 or lower it works fine.
Also if we launch an IE 11 windows outside the PWB shellbar it works inside that window.
Any idea how to resolve?
Re: Flash not working with Internet Explorer 11 in PWB
Try upgrading to the current version of PWB v3.
http://www.teamsoftwaresolutions.com/fo ... f=8&t=3045
Are you using PWB v3 CEF by chance?
Rockhard
Post by Rockhard »
Can I simply swap the PWB v3.0 exectuable when changing over to the CEF verison? Do they use the same INI. Or will I have to manually convert from the IE INI to the CEF INI File?
PWB v3 IE and CEF share the same INI file so they are interchangeable.
PWB v3 CEF has several files and folders that are distributed with it that include the CEF HTLM rendering engine. These will neeed to be copied as well as the EXE file. It may be easier to copy your INI, message, and filter files into a new PWB v3 CEF folder than the other way around.
